Nice to meet you to Mick!!!
yeah I got caught in the act of buying all this.......... cos racecar!!!
and thought it might be an idea to buy a surge tank whilst I was getting other bits and pieces.
lets just say I'll be eating cardboard for the next few weeks!!!
hopefully have almost sorted out the boost issues will finish putting in the new solenoids tomorrow and test her out!!! :)
ended up replacing the whole blackbox of 7 solenoids and 2 green solenoids as one was brittle and broke and I now have pressure in the vacuum system!!! but I'm still not getting secondary boost so first point of call is to check I'm getting vacuum in the vacuum system (separate from the pressure side of the vacuum system)
The system is so complex its a challenge to get my head around it.
The turbo control solenoid uses both vacuum and pressure to operate properly, if not then it wont transition effectively. so I need to see if the "charge control actuator" and the "turbo control actuator" are moving then it means I have vacuum and the solenoid is faulty. The charge control solenoid was in the blackbox so that should be fine! so if that's working correctly I'll see the "double throttle control" actuator moving also.
so much to check and make sure its operating correctly but I'm happy I'm getting on top of it!!!
here are a couple of pic's to show the head f*ck LOL
  • Like 1
That's the thing Brett apparently a twin turbo FD with 280kw will blow any single turbo FD away even if it has 400+kw and some guys are pushing 345kw (537nm @ 5200rpm) out of the twins.
So if I get all the vacuum system and solenoids replaced which I'm over halfway already with fault finding then it'll be good for another 12-15years (and with a vented bonnet maybe longer as there isn't as much heat in the engine bay.)
You hear so many different stories and people are trying to push there own parts ETC but apparently all the FD race stuff ie: Spirit R or Bathurst R are the best items with the least problems but then some guys swear by the single turbo setups.
Its hard to know what's right or wrong so it comes down to personal preference I guess.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
