VERY busy and productive weekend:
Replaced majority of the rear suspension bushes and the front sway bar "D" bushes.
Mounted the surge tank and pump ready to go (wont plumb it in still next weekend)
started the wiring for the gauges and surge tank - almost done I'll finish that off in the morning.
Rolled the front guards and checked that the track rims fit, just need to get some wheels nuts to suit.
and tomorrow I'm going to see a guy called Daniel Decker to get the sequential turbo working correctly and if he's nice I might get a power run on the dyno whilst its strapped down!!!
  • Like 2
Well yesterday I got my boost issues sored and whilst it was getting a boot full on the dyno the clutch started smoking LOL had an inkling that this could be the case but wasn't sure if it was the turbo transition or the clutch.
so needless to say there's new clutch going in.
today I stripped the brakes down, getting the disc's machined and some braided lines made, also replaced the clutch line with a braided one and started taking the gearbox out
I was shocked as to how complex it is under there!!! give the Stagea a run for its money LOL
had to remove the exhaust, then there is a massive brace that runs from the g'box to the diff and then all the usual braces shields etc anyways got the gearbox out now I just have to go buy a 55mm socket to get the flywheel of so that can get machined!!!
so besides brakes and clutch just have the surge tank to connect and replace the spark plugs. and I'm thinking whilst I got that brace off I might also do the diff bushes.
unfortunately I'm not going to get my oil coolers in but it should be right this time on the stock one!!!
  • Like 1
The long term plan is world time attack etc but for now I'll stick to track days and the like, hopefully even nulon national or something!
Today made more good progress pretty much good to go with a few last minute bits and pieces but whats finished is New clutch fitted with a braided line and bleed, replaced the diff bushes whilst I had half the car apart also moved the fuel filter as it was hiding behind the diff.
Got the brakes machined, painted them and fitted braided lines, new track pads etc.
The surge tank is all good to go and primed!
fitted the track rims ready for tomorrows alignment and corner weighting.
  • Like 1
I can't believe how much you've achieved in such a short space of time mate!
I know you didn't want to have to all of this before the first outing, but it's going to be such a solid base to start with.
Well done Theo. :)
  • Like 1
all went well today got the car aligned and balanced, fuel system went well although I think I may need to upgrade the fuel pressure reg to allow more fuel to go back to the tank so the Bosch 044 isn't whining as much!!! clutch went well after I bled a bit more air out of it and adjusted the height but its going to take a bit of getting used to taking off with a brass button again.
went for a cruise to put a few Km's on her and then stopped and got my race numbers put on the car!!!
  • Like 2
well it was always going to be a scramble getting a car ready in 4 weeks, spent way to much time chasing the boost issues redoing majority of the vacuum system. and then luckily got this entire week off work to get all the rest done!!!
the spanner in the works was the clutch that's for sure and I didn't even get to adding the oil coolers I wanted too!!!
but for the rest everything that needed doing got done, but thankfully for the help of a few people everything got done this week, mind you I've probably done over 70hrs in the last 6 days.
hopefully it all pays its self off with a trouble free day at the track!!!
also I'm battered and bruised from laying under the car for 4 days and my hands look like they've been through the grater :(
good thing you have 2 factory oil coolers!
also if you want a earls 10 row with fittings I have one that you could slap into the front bar I can throw in some spare braid (not fittings) that should reach if u want.. I know monies tight so we can pay later if u wish
nope I've got the base model only has 1 oil cooler :(
thanks but I've already got all the gear to do it including thermo block all the braided lines and 2 thermo cooled coolers.
just cant be bothered doing it right now and I'm hopping its not a big drama!!!
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
