  • 2 months later...
Sorry been slack and haven't done any updates in along time.
was playing Russian roulette and went out to WSID on the 4th of Feb (6 days before my track day) luckily I didn't break anything and only managed a 14.2 (but then its basically stock)
  • Like 1
Then on the 10th of Feb I went down to Wakefield the car ran really well besides having oil breather issues and lost about 200mil of oil through out the day. (Time to fit a catch can)
was really good to get a feel of the car my P.B was a 1:14 then after lunch I took John Boston for a few laps got some pointers and then sat in the b*tch seat. Boz loved how grippy the car was and how nice it was to drive - Boz managed a 1:12. Vid's to follow.
  • Like 1
Then I wanted to get the oil breathing problem sorted gave my Fab guy 2 weeks to get it done and he left it till the last minute and in the end didn't make the deadline to get to Texi :(
Didn't have enough time to get the car done and then also found out I forgot to factor in the air intake pipe when placing my fittings.
but we did manage to roll the rear guards to be able to fit my Stock Stagea rims with 4yr old 595's begging to get smoked up ahh well there's always next time.
  • Like 1
Also decided to remove the headlight and fit a 100mm air duct into the air box :)
Finally got round to fitting my diff brace, started raining and the carport got flooded so didn't have time to get the gearbox brace in
AND managed to pick up a RE Amemiya AD9 Bonnet for a good price second hand so jumped on that too!!!
anyways hoping to get back to the track on the 14th of April down at Wakefield again.
  • Like 1
  • 3 weeks later...
Hopefully get everything organized and head down to Wakefield on the 12th of May and get a bit more seat time!!!
If anyone else if keen to go, here are the details: http://www.trackschool.com.au/wp-track_days.html
  • Like 1
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
