pulse timing is a whole map calculation however like GTSboy says it is more noticable at idle and light load due to the fact the injector is opening and closing at a slower rate therefore making the latency timing more important.....its often a struggle to get larger injectors to idle well anyway...however newer tech injectors don't seem to suffer the same issues.
bump up the idle RPM to around 900~1000rpm and run it pig rich :D
The cheap man pays twice... As you just found out.
Any Sard injectors will have similar issues, and they get worse the larger they are.
I can get new 550cc sidefeeds to suit the 33 that will run fine, but that is the largest they can supply. For anything else you will need to fork out for genuine Nismo's, or swap to a top feed setup which work out around the same price.
I've been running sard 650s in my 93 liner for 9 years with the first round of PFC with supporting mods no probs,it's all with the tune,
I have been using a fantastic PFC tuner in Sydney, hi yavuz. :-)
Ok just gave all the suggestions a go, no luck
Didn't hydro lock the engine when I started it so that probably rules leaking O rings out
The car doesn't want to stall anymore, would go back to idle fine at traffic lights, unlike yesterday when I was playing with the latency. Idle holds steady and is actually driveable. Just down on power and feels like it's running on 5 cylinders.
I haven't had time to check if it's actually a bad injector just yet, could only confirm that it's not #1 caus it's the easiest one to get to
Btw these 540s should be the same injector series as those 650s, same shape, both twin sprays just different colour.
If it works fine on ur car it should be fine on mine, providing that there's no damaged injectors and it's set up properly
Edited by chiksluvit
I had my tuner do all the work,I do 30000 a year
hope you get it sorted.A lot of mechs put the sards
in the two hard basket but some can get it right,
where are you? I will recommend my tuner,uni group engineering in Sydney
yavuz is the genious with the PFC and what not. :-)
one thing you can do is grab a long screw driver stick it to your ear and put it on to each of the injector metal covers and listen for it ticking....if you don't hear one ticking it could be stuck... all 6 of my freshly flow tested 850's were stuck....
Thanks guys
Yeah I had both nismos and Sards in two of my old cars and felt the Sards did the job just as well. Sure it wasn't exactly as easy as the nismos but I didn't have to worry about breaking the pintle caps when putting them in
At least the Sards are probably easier to pull out now because it uses Allen key bolts, just maybe not the #5 and 6
Yeah I'm in sydney but I've always gone to Toshi to get my cars tuned, since he just lives around the corner for me
Will try the screwdriver trick thanks Badgaz!
Ok here's the latest update
Tried the screw driver trick, could hear all injectors going
Pulled the plugs on #1, 2 and 6, all seems to affect the engine. Couldn't get to the plugs on 3, 4 and 5
So went back in the car and tried to adjust the latency on individual injectors, individual changes made to 2- 6 affects idle except for #1 cylinder.
I could put the latency correction to -1 and it won't make any difference, yet if I pull the plug then it will. So it seems like #1 injectors delivering fuel but not responding to latency changes
Can this happen? I thought injectors either die or alive?
PFC is brand new when a bought it a couple of mths ago, so I doubt it's the ECU
do you have a wideband? if you can get the afr's roughly right it should be driveable.... you'll need to get it to a tuner with a fcdatalogit.
Nuh I don't have a wideband
It is driveable, just lack of power and sounds like wrx, I already took it around the block a couple of times today when testing it. Lucky toshi doesn't live too far away so I can get the car to him once I replace #1 injector if it is a dud
At least if it's really #1 then I won't have to pull the rail out again, it's easy to access that injector
I'm just puzzled at how it could be possible that an injector is delivering fuel but not respond to adjustments made while others do, in both fuel % and latency
not much he can do about it now
he reckons its likely that either one of the injector's dud or ECU or coilpack is stuffed
seeing it was runnings 100% before the injectors i guess one of the injectors needs to be replaced :/
will be checking the spark plugs later
Update: as Toshi has suggested I've taken the spark plugs out and had a look at it
they were all running rich judging by the spark plugs, this is from cyl 1, the rest all pretty much looked the same
AFAIK they all still produce spark- engine drop revs when each of the injectors were unplugged, including #1
Only thing suss- cyl # 1 injector doesn't respond to changes on the PFC
Changes on every other injector affects idle
so could be the PFC, could be the injector. The PFC is only 6 mths old and injectors were also new
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
