Talk to Greg @ Race Brakes in Wetherill Park Sydney. (They do brake kits, probably able to post if need be).
I got my 324 x 32 mm rotors from there and im wrapped in them. They are slotted, but not cross drilled. I dont recommend getting cross drilled rotors, especialy on road cars. Rotors can still use factory Nissan Caliper, with a bracket to accomodate larger diameter.
I looked at the Apexi untis as well, they are 2-piece where mine are single, but the Apexi rotors are no bigger than factory.
You should at least talk to Greg or Avian, they may be able to give you a better option, or feedback on what you are looking to buy. Great service/quality and dont sell you things you dont need. (Brake kits to your application)
Only thing is try and get rotors that are slotted all the way to the outer edge, this stops pad build up and a groove wearing into the rotor where the slot stops on the face of the disc. (really no big deal)
https://www.sau.com.au/forums/topic/4473-apexi-brake-rotors/#findComment-70535
