Hey Guys
As I stated in my first post im only 17yro. So im still on my red ps. Meaning I can only drive my r33 on the track!
I live in Sydney, Nsw.
Whats the go with track hire or going to the track with my r33?
And whats the cost and conditions?
Do I have to do my cams licence. And if so. What exactly is it that you do for it?
A test? Or just a course to say you've completed it?
Thanks in advance.
Tyler
https://www.sau.com.au/forums/topic/447317-track-dayscams-license/
Tyler you need to join a cams affiliated car club like SAU NSW.
Then you can apply through CAMS for your license. As you are classed as a Junior you will just need your parent or guardian to sign the form too.
You need a L2S cams licence. See here:
http://www.cams.com.au/get-involved/competitors/getting-started
You need a car club affiliation to go with it. If only there was a Skylines club that held track days..........
SAU NSW has a track day in September... Check the events section!
Yah or you can also get a club racing license through SAU once your a member. This covers you for most of our club days including the upcoming one at SMSP and texi. I currently just have this license. But if your racing more often then a CAMS one is much better.
Does the cams licence allow you take a passenger?
Ive read on a few sites and called a few places (wakefield etc etc) and they said no passengers are allower.
How do I join SAU?
Yes.
And no.
It depends on the event. Some such as rally sprints allow you a navigator. You are allowed an instructor at times. And on some practice/ride days passengers are allowed. But it depends on the event and on what the circuit allows the event organisers to do.
Best bet would be to get a AASA. Licence to begin with only $50 I believe, doesn't require you to be a member of SAU, but highly recommend you do for cams licence and other good deals
Then go to events section and enter into SAUNSW trackday next month and bring your friends who will be able to be passengers with you during the day
And can also fill out a form to join SAUNSW on the day
Ok sounds good
Ill try get that done soon. In the next week or so. Hopefully my cars out by then. Still has to be broken in and dyno tuned so may be strapped for time.
Thanks guys
Broken in? :blink:
The cars currently at meer motorsport blacktown getting an engine overhaul.
Forged pistons
New turbo
Metal head gasket and head studs
Injectors etc etc
The lot
Was only on like 70psi on one the cylinders from running to much boost from the previous owner. We paid nothing for it though so its still a cheap car for the power its going to put out.
Ok sounds good
Thanks guys
run in on track? ;)
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
