Hi everyone.
Just thought I would share my experience with you all.
I recently insured my r34 gtr v-spec with Shannons at a premium of $2250 ($500 excess). I was told by a guy at work about nrma vintage. Catch is you have to only do no more then 9000kms per year and your car 15 years or over and obviously a clear driving history for the last 2 years. All no problem for me.
Anyway nrma premium came in at only $975.55 (300 excess.). A saving of more then $1200. And agreed value was no problem.
  • Like 6
https://www.sau.com.au/forums/topic/447336-nrma-vintage-and-classic-insurance/
1800646605 is the direct number to NRMA's Classic, Vintage and Veteran.
Good post above!
Big savings can be had if...
* your car is at least 15 yrs old
* it's not your daily
* well secured
* travels less than 9000km/yr
* high sum insured may need to be supported with pics
The direct number above is advised over the usual NRMA Insurance arm (number).
  • Like 5
Changed from Shannon's to NRMA today.
Half the price of Shannon's !!!!!!!!!! only catch is you can't pay monthly, has to be an up front annual payment.
And YES, mods are allowed in the policy no problem whatsoever.
  • Like 2
HAHAHAHAHAHA
Just called NRMA
Quote came back @ $509
Shannons charge me $2200 a year
that is literally laughable
What model? Insured value? Age?
That's a bargain. I thought I was doing good at $975 compaired from Shannons $2200.
I'd say Shannon's arguing to lose a fair chunk of clients once word gets out.
It there own fault for being greedy. A little competition is good for us.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
