Yep as Peter said, you can choose to keep a log book for your peace of mind that's totally fine. I'm just saying NRMA are relying on their customers to be honest, otherwise they would be writing down all this stuff, or keeping their own log books on every one of their customers.
  • 4 weeks later...
On 2/27/2016 at 2:50 PM, Aqua said:
Ok, so I have decided to make the switch from LSV to NRMA VVC
Instead of the first quote of $75,000 agreed value and $1,080 Premium,
after listing all my mods, I have brought it up to $80,000 agreed value.
$1,130 Premium and $1,000 Excess.
Slightly cheaper than LSV but insured for alot more :smile:
Hi all, just renew-ed my policy so FYI:
NRMA VVC renewal letter came in with $972 premium and everything else e.g. agreed value and excess being the same as last year. Pretty delighted the premium actually went down!
However I gave them a call and increased the agreed value to $110,000, with $1,000 excess and $1,490 Premium.
Note:
1) With premium over $100k, the excess has to be $1k, no more or no less.
2) Apparently there's an endorsement from the underwriter - they will not insure a car over $100k value if the driver is under 30 years of age. The lady from NRMA VVC has waived this for me though.
Hope this helps!
  • Like 3
  • 4 weeks later...
20 hours ago, drifter007 said:
I inquired about insuring a r33 GTST and nrma vintage said that they no longer consider it a collectible car and aren't willing to insure it. Any other alternatives, i dont want to pay 2k+ on insurance...
wow... dafaq!!
I just renewed mine a few months back. hope I can do it again this year
36 minutes ago, Dose Pipe Sutututu said:
wow... dafaq!!
Yeah, so devo. They said the change was made only a few days ago but i'm not sure how true that is...
Who were you with prior to NRMA?
Here in vic and currently with RACV, insurance is due and comes up to $1,650 for a 96 r33 vspec. Tried to get insurance with shannons last year but because it was my first year on full license they said come back next year. So renewal is up and Shannons basically matched the premium and set the agreed value at 30k. Gave RACV a ring to see if they could match the agreed value and they said nope max 25k for the 33 vspec, despite the fact agreed value for a  33 gtr non vspec can go up to 35k (did this by accident when i was checking agreed value limits online but clicked the wrong model).
If your R33 is not your daily and is garaged, get VVC.
No under 25, if this person has only had their full licence for 12months.
Got told the same thing by RACV and lumleys. Shannons also knocked me back until I was 24 due to having driver training and cams licence (min was 25 at the time)
They didn't have any age restriction, i think Shannons didn't like that i was coming from a 2l subaru to a gtr, racv didn't even bat an eye lid. I do take it to work one or twice a week so vvc was out of the question for now. Think i'll just change to shannons for the higher agreed value.
  • Like 1
  • 5 weeks later...
Im not sure about age restrictions, but this will be my third year under vvc and im 22 with a 1990 r32 gtr.
Renewal came in at $350, insured for $25,000
I decided to up the agreed value to $40,000 for $447 per year.
No questions even asked, they just wanted to confirm my mods list.
  • Like 3
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
