Is there an equivalent "Classic, Vintage & Veterans" Insurance in other states better known as...
* SGIC in SA and...
* SGIO in WA ???
Good suggestion Tez , I gave SGIC a call and that insurance does not exist in S.A not sure about W.A , i did however tell Shannons i am driving my car less ,
so they reduced my insurance from $1200 to $ 930 / year for R34 GTR .
I didn't realise how expensive insurance is interstate , i thought S.A would be the worst as everything else - e.g. registration is one of the highest .
  • Like 1
Well Dave Snape Mngr of NRMA Classic, Veteran and Vintage and I were discussing how he would like to come to a SAU.NSW Exec Meeting in the near future. I'm not an Exec anymore but perhaps the question needs to be asked about parity across SGIC and SGIO as well?
  • Like 1
so what if you drive more then 9000kms a year ? do they cancel the policy or ?
Not sure, but I was never asked to provide ODO meter readings. There is no mention in the PDS about providing evidence of said KM's per year other than 9000km or less.
What one says over the phone interview is a contractual agreement - and it's recorded.
And each year's pink slip can be checked retrospectively through RMS yes as per previous post.
  • Like 1
Power of negotiation can work wonders - especially if salespeople with clout can sense that your moolah might indeed, walk away.
Tez, have him look me up and call me at work. Prob can't fit it in tomorrow but since I work at IAG should be able to catch up with him.
Wow this will be very interesting to have a different perspective and added information :)
Dave Snape said this morning that he's already emailed the NSW Prez.
He says that interstate enquirers are welcome to call him directly on 0411011205 and still procure NRMA Classic, Veteran and Vintage coverage subject to the top 2 posts on this thread.
Evidently the junior staff on 1800646605 are on a steep learning curve but they are eager to please.
  • Like 1
I called Shannons to see what they could do for me. They said lowest they can go is $1500. I told them i'm still saving $1000 a year and will be cancelling at the end of the month and going with NRMA.
Another loyal Shannons customer making the move. $800 saving compared to Shannons limited use policy, and increased value
Can't argue with that.
On a side note, haven't spoken to such a helpful customer service team in a very long time.
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
