do it yourself.
it's ust some torx bolts and then a big Fker under the airbag.
and as long as you have battery disconnected during the process and don;t break any wires you will be fine.
Else any workshop will do it for you next time you take it in for a service.
  • Like 1
never needed one of those.
I jsut loosen the main nut (not all the way off)
then give the old wheel a few yanks and it comes loose, that allows you to make sure everything is straight b4 and not rip cables.
then take it off and put new one on.
^ This
It's a simple job, like Martin said, make sure you disconnect the battery
Also make sure the wheels are straight so when wheel goes back on it's the same position as the one you swapped it with
I've had to pulled off 2 steering wheels and both times, yanking just wouldn't work haha, oh wells..
Okay going to have a go at with a friend see how I go, one more question the nrw stering wheel has had its airbar denator removed for shipping purposes can I easily use the current one? And if anyone can explain what it looks like lol
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
