Hi all,
I've got the following for sale as they are no longer required. I'm located at Newmarket/Ascot Vale area and would prefer pick up but also willing to post at buyer's expense. Pm me if interested or if you have any queries.
1. RB25 HKS drop in cams 256/264 - Used and in good condition - $550
2. 6 x Nismo 555cc side feed yellow top injectors - Used and in good condition - $550
3. R34 GTT stock turbo - Purchased as a spare - $300
4. CBC wheel bearings 2 x front (NJ246) and 2 x rear (NJ134) - - New - $550 for the lot.
5. RB25DET complete engine gasket kit - New - $250
6. R33 JJR dump/front pipe and Catco highflow cat - Used and in good condition - $250
7. Z32 AFM used with new Tomei plug - $200
8. R32 GTR Nismo fuel pump - used and in good condition - $250
9. R34 GTT rear brakes includes calipers, new pads QFM HPX and used discs - $200
10. JJR RB25DET silicone heater hose set (missing 2 pieces) - $100
11. R32 stock 10psi actuator - $30
12. R33 snorkel - $30
13. RB25DET valley cover $20
14. Camber correction Superpro and Whiteline Bushes (SPF3154K, SPF1869K & KCA347) - New - $350 for the lot or $130 each.
Cheers,
Kandio
Price drop!
1. RB25 HKS drop in cams 256/264 - Used and in good condition - $500
2. 6 x Nismo 555cc side feed yellow top injectors - Used and in good condition - $500
4. CBC wheel bearings 2 x front (NJ246) and 2 x rear (NJ134) - - New - $500 for the lot.
5. RB25DET complete engine gasket kit - New - $220
6. R33 JJR dump/front pipe and Catco highflow cat - Used and in good condition - $220
7. Z32 AFM used with new Tomei plug - $170
8. R32 GTR Nismo fuel pump - used and in good condition - $220
9. R34 GTT rear brakes includes calipers, new pads QFM HPX and used discs - $170
10. JJR RB25DET silicone heater hose set (missing 2 pieces) - $80
11. R32 stock 10psi actuator - $20
12. R33 snorkel - $20
14. Camber correction Superpro and Whiteline Bushes (SPF3154K, SPF1869K & KCA347) - New - $300 for the lot or $120 each.
Cheers,
Kandio
The cams are for series 2 RB25DET and still retains VCT and are direct drop in replacement.
The cams were purchased used from another member years ago and I never got a chance to fit it in my car.
The previous owner said he'd done about 10,000km's on it and it does appear to be in very good condition still.
All PMs have be replied to.
Cheers,
Kandio
Edited by Kandio
6. R33 JJR dump/front pipe and Catco highflow cat - SOLD
7. Z32 AFM used with new Tomei plug - SOLD
11. R32 stock 10psi actuator - SOLD
Edited by Kandio
  • 1 month later...
  • 3 months later...
  • 1 month later...
  • 2 months later...
This is what is left guys. Make an offer if you like. :)
3. RB25DET complete engine gasket kit - New - $220
4. R32 GTR Nismo fuel pump - used and in good condition - $220
5. JJR RB25DET silicone heater hose set (missing 2 pieces) - $80
6. R33 snorkel - $20
7. RB25DET valley cover $20
8. Camber correction Superpro and Whiteline Bushes (SPF3154K, SPF1869K & KCA347) - New - $300 for the lot or $120 each.
Cheers,
Kandio
Cams, injectors and gasket kit sold.
Below is what's left.
1. R32 GTR Nismo fuel pump - used and in good condition - $220
2. JJR RB25DET silicone heater hose set (missing 2 pieces) - $80
3. R33 snorkel - $20
4. RB25DET valley cover $20
5. Camber correction Superpro and Whiteline Bushes (SPF3154K, SPF1869K & KCA347) - New - $300 for the lot or $120 each.
Cheers,
Kandio
  • 7 months later...
Some items left for sale. Pm me if interested.
2. JJR RB25DET blue silicone heater hose set (missing 2 pieces) - $80
Cheers,
Kandio
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
