whats the go with the rx injectors.Ive heard that they have a different spray pattern and at xtreeme power levels for them in the rb they can sometimes fail.Sounds like bullshit to me.:cheers:
Atomisation is for economy and lower emissions. If fuel is too atomised then it can actually part stall because the volume to surface area ratio is lower. Fuel vapourises upon entry into the combustion chamber under extreme power.
I think you're right about it being BS. That is open to a wide range of interpretation but assuming the engine was not running lean then I still expect that if this ever happened and they were ever able to determine the specific cause then they were probably being run easily past 80% duty. I should also add that the side feed injectors are later model than the top feed.
Simply, Blitz use the exact same 550cc side feed injector that comes in the later RX-7s, only difference is it's brand new. Greddy and others sell brand new the 12aT and S4 injectors brand new. All injectors should be cleaned and flow tested before being used. Flow testing even if they are new, that's exactly what Blitz and Greddy do. The injectors are made by Denso. Mazda buy their injectors from Denso just like Blitz and Greddy. Only difference is Mazda actually charge more for theirs.
Im going to try and source some injectors they definently wont be run past 80% more like 70%. with your fuel rail is it a stright bolt in application for 13b turbo injectors?what will i have to do for me to get a perfect fit?
Im going to try and source some injectors they definently wont be run past 80% more like 70%. with your fuel rail is it a stright bolt in application for 13b turbo injectors?what will i have to do for me to get a perfect fit?can i still retain a sard fuel pressure regulator?
The side feeds can be run higher duty, they are a later design.
Do you have an RB20, RB25 or RB26?
The kit is only necessary on the RB25 as they are the only side feed.
RB20 and RB26 are top feed, I can get direct fit. Only difference is impedance, RB20 is high and RB26 are low. I usually can either low or high but don't have any right now.
Send me a PM with your email. Let me know what you need, I will let you know when I have some.
rb25det.and i am wondering if the oe fpr will fit this new style rail?
Direct fit, no need to change any rails or anything. You only need to change rails when you use top feed injectors on RB25. The fitment kit is so you can keep your factory RB25 rail and use side feed injectors.
still having troubles getting some.Ill get back to you when i have an answer so dont go anywhere.:D
I won't :D
Even if you want to come up with some and I will see if I can come up with some, if not all, of the others. Plus we could do part swap for primaries and secondaries too (primaries 550cc, secondaries 850cc). I can also modify them and test them as a set too, basically a hobby at this stage but we'll see if I can turn into something else.
Yeah thats all ok but im not after any secondaries only cause i dont need them the primaries are the ones i want.Ive tried a local place today and they have none so i will try a proper mazda wreckers tomoz day.
How much are they usually for a second hand set of 555cc 13b t jobbies in new zealand?
How much are they usually for a second hand set of 550cc 13b t jobbies in new zealand?
hi i got this off meggala @ http://www.meggala.com/injectors.htm
RB25
high impedance side feed.
these are very expensive supplyiers are nismo, apexi,denso,sard, HKS,Trust
sizes avaliable 550,660,740,850 cc
use the cc rating to give you a guide as to how much hp they can handel there is a formula which I will include later .
s/hand after market options.
s15 sr 20 engine is reputed to have 480 cc injectors (hard to find)
20b rotary engines are believed to use 850cc injectors.
people fit a new fuel rail to enable the use of top feed injectors but you would still need high impedance if you are using a modified stock ecu or a resistor pack to change impedance.
RB20
high impedance top feed.
the main choice is from the series 5 rx 7. these are 550cc injectors (they are denso and the part number is 195500-2020).
nismo make 2 as well 550 and 600 cc.
But I believe that you can use low impedacnce injectors with a resistor pack from a gtr this has not been confirmed.
this means that i will need a hose tail feed is this what your kit caters for?
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
    • Can you covert an R32's AC from r12 to r134 if the compressor/hoses etc are still all good? Pretty sure on my car the AC was degassed when it was imported  to remove the naughty r12 and save the ozone layer, and the fancy climate control system just blew air around. Was happy to drive the car with windows down back then, but now I am old and need to be kept cool
    • Just to circle back here, I've sold my automatic trans to another Stagea owner in OH.
