whats the go with the rx injectors.Ive heard that they have a different spray pattern and at xtreeme power levels for them in the rb they can sometimes fail.Sounds like bullshit to me.:cheers:
Atomisation is for economy and lower emissions. If fuel is too atomised then it can actually part stall because the volume to surface area ratio is lower. Fuel vapourises upon entry into the combustion chamber under extreme power.
I think you're right about it being BS. That is open to a wide range of interpretation but assuming the engine was not running lean then I still expect that if this ever happened and they were ever able to determine the specific cause then they were probably being run easily past 80% duty. I should also add that the side feed injectors are later model than the top feed.
Simply, Blitz use the exact same 550cc side feed injector that comes in the later RX-7s, only difference is it's brand new. Greddy and others sell brand new the 12aT and S4 injectors brand new. All injectors should be cleaned and flow tested before being used. Flow testing even if they are new, that's exactly what Blitz and Greddy do. The injectors are made by Denso. Mazda buy their injectors from Denso just like Blitz and Greddy. Only difference is Mazda actually charge more for theirs.
Im going to try and source some injectors they definently wont be run past 80% more like 70%. with your fuel rail is it a stright bolt in application for 13b turbo injectors?what will i have to do for me to get a perfect fit?
Im going to try and source some injectors they definently wont be run past 80% more like 70%. with your fuel rail is it a stright bolt in application for 13b turbo injectors?what will i have to do for me to get a perfect fit?can i still retain a sard fuel pressure regulator?
The side feeds can be run higher duty, they are a later design.
Do you have an RB20, RB25 or RB26?
The kit is only necessary on the RB25 as they are the only side feed.
RB20 and RB26 are top feed, I can get direct fit. Only difference is impedance, RB20 is high and RB26 are low. I usually can either low or high but don't have any right now.
Send me a PM with your email. Let me know what you need, I will let you know when I have some.
rb25det.and i am wondering if the oe fpr will fit this new style rail?
Direct fit, no need to change any rails or anything. You only need to change rails when you use top feed injectors on RB25. The fitment kit is so you can keep your factory RB25 rail and use side feed injectors.
still having troubles getting some.Ill get back to you when i have an answer so dont go anywhere.:D
I won't :D
Even if you want to come up with some and I will see if I can come up with some, if not all, of the others. Plus we could do part swap for primaries and secondaries too (primaries 550cc, secondaries 850cc). I can also modify them and test them as a set too, basically a hobby at this stage but we'll see if I can turn into something else.
Yeah thats all ok but im not after any secondaries only cause i dont need them the primaries are the ones i want.Ive tried a local place today and they have none so i will try a proper mazda wreckers tomoz day.
How much are they usually for a second hand set of 555cc 13b t jobbies in new zealand?
How much are they usually for a second hand set of 550cc 13b t jobbies in new zealand?
hi i got this off meggala @ http://www.meggala.com/injectors.htm
RB25
high impedance side feed.
these are very expensive supplyiers are nismo, apexi,denso,sard, HKS,Trust
sizes avaliable 550,660,740,850 cc
use the cc rating to give you a guide as to how much hp they can handel there is a formula which I will include later .
s/hand after market options.
s15 sr 20 engine is reputed to have 480 cc injectors (hard to find)
20b rotary engines are believed to use 850cc injectors.
people fit a new fuel rail to enable the use of top feed injectors but you would still need high impedance if you are using a modified stock ecu or a resistor pack to change impedance.
RB20
high impedance top feed.
the main choice is from the series 5 rx 7. these are 550cc injectors (they are denso and the part number is 195500-2020).
nismo make 2 as well 550 and 600 cc.
But I believe that you can use low impedacnce injectors with a resistor pack from a gtr this has not been confirmed.
this means that i will need a hose tail feed is this what your kit caters for?
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
