I'm after some infomation, my car was tuned on caltex eflex, will I be able to use united e85 in my car if I ever wanted to, if I was around no eflex, and would it drive and perform as normal? I know caltex say the E% varies from 70-85 and they change it to suit the Seasons of the year, and united % is gaurnteed more, would the difference in e% change the way it performes?
https://www.sau.com.au/forums/topic/447351-running-on-e85-if-tuned-on-flex/
There is no e85 close by, probaly about 30-40 minutes away, but there is eflex one 10 minutes from my house, thats more the reason behind it. Only asking coz there seems to be more and united coming up around the place
I do have flex fuel sensor sniffer what ever you want to call it, the ecu has dual maps from 98 and eflex, so can't use either of them with what ever in the tank, just wasn't sure about e85 because it wasn't tuned on that
What do you mean on how it was tuned? With the fuel maps etc?
Whether the tuner has left left some leeway so that if you do put e85 from e70 and you run half a point leaner it doesnt matter but if it was tuned to its max and now you suddenly run it a point leaner it will affect you. Do you know what your A/F ratio was on the e70 tune?
Oh yer true, umm don't know of the top of my head but I'm thinking that there is leeway there.
It also depends on how Eflex is in the tank and how much E85 you put in, empty tank then fill to top will change the E% more then half tank adding 20l
I don't get this, cause the only way this would be plausible is if you emptied the tank to change from one to the other, contact your tuner and ask if he has setup a flex tune
If tuned for E70 and had to use E85 it's simple to toss ULP in to make it E70 . Its a 15% difference you can work out based on an almost 60L tank . Works out to 2.25L of petrol to every 1/4 tank so 2.25 / 4.5 / 6.75 and 9 litres . I'm sure 3 5 7 and 9 would work fine and if you have a wideband wired it would compensate enough for normal road use .
Just don't bugger it up watching the dollars instead of the litres or carry a clean dry 10L container in the boot .
A .
    • Thanks mate 👍 The car was brought into the UK by a USAF mechanic until he was stationed back to the US, one owner later I bought her back in 2009. Luckily the only corrosion was on the sill seams, so once taken back to metal and treated and sealed all ok, I then undersealed the car myself and check yearly and treat any corrosion which to be honest is zero. She's garaged most of the time and hardly ever driven in the rain, but as you say most are rotten unfortunately, I was lucky in finding her as she was and still is in excellent condition.
    • Stunning car.  Looks amazing!  You're in the UK?  How the hell do you stop your car rotting away beneath you?  British cars are the WORST I've ever seen in regards to rust.  Some of the cars SR Autobody have done are borderbeyond saving.
    • not a date code? or a foundry code?
    • I have up to date pics of the engine build and turbo conversion over on my instagram @skpro_jects if you want to take a deeper look.   Basically the exhaust manifold is straight bolt on and the ports match (they arent any smaller than a 25 or 26 head).    the intake ports are different shape so the 20/25det manifold will bolt up but wont match properly or seal. You will need to port match using the 25det gasket as a stencil. Personally i ran the entire stock 20neo intake setup and have configured the swirl valves and torque valve to work based on my custom parameters to help with off boost response and spool. But this is using a standalone aem v2 ecu. The stock 20det ecu wont be able to control them.
    • Hi. a little later but if the topic is here. So...the exhaust is the same and you can use 25/Turbo or any aftermarket? What about intake side? Is it too "plug n play" or? (i do not remember for 100% but i think that one intake to head gasket was little bit different than on the RB25 - i bought gasket kit way back) I know that even if it "plug" those butterfly swirls would cause ECU to be confused or?   Just asking for the info 🙂 and of course the RB25 things are easier to come by
