Hey mates I'm just looking at the dyno sheet I got with this beast. I'm wondering about the boost curve. Does it show that it doesn't make full boost until 7500 rpm? I would expect it to make that at worst case 5700rpm then the line to stay flat till max rpm.
It's a gt35 .82 rear on a rb20. Garrett turbo. China stainless manifold. 38mm wastegate screamer pipe.
Boost controller is a turbo smart dual stage manual one.
No idea what spring is in wastegate
Looking for some ideas on if that's how it shud be or if something's goin on with setup.
I understand its not the ideal size turbo but that's what's on it. Il live with it
Thanks mates
https://www.sau.com.au/forums/topic/447367-rb20-gt35-dyno-graph-boost-curve/
Have a look through the RB20 Dyno sticky thread. For example, the dyno sheet on the top of the last page shows the sort of shape you should be aiming for manifold pressure (boost). I'd guess your setup is always going to be horrible with a turbo that big. Suggest you change your mind about living with it. You want to enjoy driving your car don't you? :)
Yea I've seen a lot of dyno sheets on there. I believe it should be as I suggested and reach full boost at a certain point in the 5000rpm range and hold it but want to confirm something may be up with mine and if something isn't right suggest what is causing it.
Edited by joe blo
The turbo is too big, and the .82 housing is more suited to a 3L engine. A stock RB25 turbo can make that power, and come on by 3k on a 2L.
It could make bulk KW if you were willing to rev it to 12k and make use of that amount of airflow. (porting heads, massive cams etc.)
Yes, the peak boost is at 7500rpm but that's not so much a factor of turbo lag as it is boost control - its boost creeping which is why it keeps climbing and ending up at it's highest there. Looks like the gate is opening at around 6000rpm, which is closer to your expectations and I'd say is probably more or less what you're going to get on an RB20.
  • Like 1
Yea I did consider it could be boost creep but I thought that if it could hold the 12 psi setting fairly well it should be able to control 21 psi.
If I put a spring closer to 21 psi in the wastegate could that make it better? Could probably assume the current spring is below 12 psi
That will increase the boost, you should hit 21psi by 10k or so. :P
An electronic boost controller may help with the boost curve, but a heavier spring will definitely be required in the wastegate.
as said totally wrong setup so 7500 would be correct
to give you an example I ran an rb22 with gtx3076 with 0.82 tial 44 Vipec 88 and e85 with basically everything you can get for that setup (cams dialled in etc) and had full boost at 5200
as all said above get rid of that turbo its never going to work
food for thought (ignore if you wish).
  • Sell turbo
  • Sell manifold
  • Sell gate
then
  • buy a brand new hypergear highflow
  • stock manifold
  • spend all leftover cash on hookers and cocaine
  • and whatever is left on tyres
  • Like 1
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
    • I was chatting with an ex SAU person who is involved in chooning euros now. He was saying the factory cars like Audi VW etc have something like 2000 tables that the ECU uses for getting everything "just right". Compare that back to any aftermarket ECU, and you'd be hard pressed to surpass 50 lookup tables. Even the Ford Barra engine has a few hundred lookup tables to run it (and they're still working some tables out too!)
    • Grab a temp probe, and probe each exhaust inlet runner with it sitting idling. Each one should be pretty darn close to the same temp. If you've got some reading higher or lower than the others, it's likely either air flow isn't equal, or your injectors aren't equal to each other.   The other things to check, is from the wiring changes that were made, were any earth's or grounds moved/changed.   Lastly, for the strut brace issue. It's not perfect, but can you get away with slipping a washer or two under the strut brace to raise it, and it still clean the bonnet? If you can, work out the height you need, that the motor can't torque up into, and get a spacer made for each side.
