Yikes!
Makes me think of my drive shaft.
But man, the rest of the damage is nuts. How hard was the launch?
Full tilt launch on street. Broke immediately.
I'm on front nismo LSD so it goes pretty good but the only thing i can figure is the mounts sheared then the motor jumped and then the axle went. Yours looks insane!
Wow how did you do that?!
4
Very similar circumstances, but mine lasted 5 mins of normal driving after before the clunking started. :D
Fairly standard for OEM mounts to be shagged, break like that and cause similar damage... It sucks, I've been lucky enough to do it but my turbo hit the strut bar, ripped off the cooler piping and lost power almost instantly causing no real damage.
Nismo are much better but tend to cause issues with the fan hitting the shroud
Older ones but they looked and felt good. Strane to me where they both sheared where they are bonded to metal.
Don't have a video of this launch but do of others. I was just doing the burnout this time doing some testing.
  • 3 weeks later...
Installed all of it yesterday. Getting those motor mounts in was a total PITA. The fan shroud, however, was easy (didn't even need to remove fan or belt).
Nismo Engine mounts
Nismo Transmission mounts
New Nissan fan shroud
Used axle (New CV boots)
New fan shroud
Cranked the car just to get it running. Ran no problem but I need to fill the front diff fluid level today and then I can drive it.
Needed to lower the subframe on each side while jacking engine up to get mounts in - managed to do this with axles in and most components still hooked up but was PITA running pry bar and all by myself while wedging the mounts into place.
My advice now is if you are EVER getting at your mounts or removing/installing the engine do the nismo mounts right then!
sounds like fun! just make sure its got the early transfer case with no preload on it. (ie with car up on a hoist you should be able to turn the front prop shaft with no resistance turning the rear shaft.
or you will kill it in rwd.
the preload in the 33 and 34 gtr is from the attest computer, it's not mechanically different to the 32. But I reckon the 32 still wears its plates a little even without the preload factor when running without the fuse, especially when dyno tuning. As long as the front prop shaft is out you'll have no dramas with the transfer case running the car in rwd.
the preload in the 33 and 34 gtr is from the attesa computer, it's not mechanically different to the 32. But I reckon the 32 still wears its plates a little even without the preload factor when running without the fuse, especially when dyno tuning. As long as the front prop shaft is out you'll have no dramas with the transfer case running the car in rwd.
Edited by doo doo
i beg to differ... i have been around the block a few times with these things., but i agree, pulling the shaft is the best choice. fuse out and crack off the bleeder and if it still drags you need to pull the shaft.
Yeah I know you know your stuff, I recall this being discussed on here a few years ago too, and as far as I'm aware you can disable the preload in the 33 via the computer. Happy to be proven wrong, I rebuild the transfer cases with increased preload now anyway which means pulling the shaft on the dyno.
How to put your R33 in to 2wd (from the manual):
Locate the "air bleed" wire behind the drivers kick panel, it's a plug with a single wire either side (usually green socket, white plug).
Disconnect it.
Start car. As key comes back to the ON position, within 10 seconds, depress brake pedal 5 times, 4WD light will start flashing to indicate you are in 2WD mode.
To go back to 4WD mode, turn car off, reconnect plug and off you go.
I have hooked mine to a switch in the centre console.
  • Like 1
  • 1 month later...
More dyno fun.
Finally moved my cam gears on the dyno. Spent 4 hours there yesterday (on a dynocomm inertial - which will soon be eddy brake). I now see what a V-cam would do for you. Moving my Poncam A's closer together (ie-more overlap) yielded undeniable tq gains with no appreciable drop in top end power (my 3" exhaust could be holding me back). I think it liked 8 total degrees of CRANK overlap (2 notches off from '0' on each cam) the best (Advanced intake 4, Retarded exhaust 4), but we did run add another 2 deg (crank) to the intake to bring it to 6 deg intake advance and 4 deg exhaust advance and this is where it stayed (for now). Super choppy idle now, but damn this car pulls like CRAZY now. makes 3 more psi boost at 4k rpms. When I compared 20 psi runs with cams set at 0 the tq goes to the stratosphere. Look at the differences from 4500 rpms to 7k! At 22 psi high number is now 653 whp and 515 wtq but boost control was shakey on these runs (oscillating from 22 down to 18).
It is making 300 WHP at 4k rpms on 20 psi...on 93 octane pumpgas! This is my 8374 EFR .92 IWG on a stock-bore 79mm BC stroker FYI.
58ab246eadbcb_DynoCamchangesconverted.thumb.JPG.403334239ea14914086aebe9dfb556eb.JPG58ab244687e7b_Lastdyno20psicamsset.thumb.jpg.a1565b209b5cae19e58f187a236c178f.jpg58aaff4ca6635_Justhighnumbers.thumb.jpg.e300231a1d0c3e828ae0fabf7265f6ae.jpg
  • Like 2
1 hour ago, SimonR32 said:
Those cam gear changes certainly woke it up!
I'm really thinking the stroker geometry and slow top end piston speed must REALLY like more overlap than I was giving it with these small Poncam A's and straight up cam timing. I just drove it again...damn car is an ANIMAL! I can not wait to try another 1/4 mile run in it! I can only imagine what a 3.2 with V-cam would be like!!!
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
