Thinking...time attack. Maybe the only thing the wife will be on board with. I won't be doing any physical car work for a couple months at least.
Notice there are NO brake marks in the picture at the end of the road...
I'm not going to talk about what happened yet but seems throttle stuck and I had no brakes at all. 20171216_195420.jpgdownload_20171217_180044.jpgdownload_20171217_180037.jpgdownload_20171217_180012.jpg
  • 3 weeks later...
Been awhile... But I'm coming back to life slowly. 2 cracked vertebrae are definitely in there. Back brace and very light duty for 2-3 months, but no surgery needed. I was extremely fortunate (thank God).
Good news is I picked up this beauty local. Gts-4 that needs a little work but he has all the parts to put it back together save for a hood and front bumper. Oh and I bought my car back from insurance! It's destiny is the widebody gutted caged racecar I should have built in the first place!
Things to look forward to gentlemen. Less weight, more grip, safer car!
received_176031932994895.thumb.jpeg.006a24d95c42b51bc3ca048f55dde22b.jpegreceived_901213153380907.thumb.jpeg.0e72930ea6664147045c94b44b59e93c.jpegreceived_901212060047683.thumb.jpeg.2e9c347a5447086bb36e42e3b5fa7009.jpegreceived_901212133381009.thumb.jpeg.3833f8a84b629b1eea39893bde1e8f03.jpeg
  • Like 6
So wait, you're putting the stuff into the GTS4 shell and turning that into the track car, or turning the GTR into a track car and turning the gts4 into the every day fun car?
Also, sorry to hear about the inccident
GTR chassis is pretty much bent in half. All the GTR stuff into GTS4 as full caged track car. Super widebody though is the plan.
  • 2 months later...
Plot twist - Made a deal on this.
Motor runs well. New -7 turbos, new exedy hyper single clutch, intakes, exhaust, new HKS hipermax coilovers, stock interior, stock paint (not perfect, but workable), perfect dash. No wrecks from anywhere I can tell. Also comes with new in box Haltech platinum PNP.
Getting excited! Found it local just about when I was getting the GTS-4 put back together.
I will say the -7 were a little more laggy than I was expecting. I guess stroker + EFR has totally spoiled me.
Sorry apparently had something on my camera lens. Oh and the car was super dirty from sitting in a warehouse for months.
  • 3 weeks later...
  • 8 months later...
  • 1 year later...
Well...Lots of other projects out of the way. New house, new move, same hurt back (but I manage). Finished most of my other racecar projects (couple of E36 M3's with LS swaps and a MR2 Spyder with a 2zz 6 speed swap), but I'm getting back at it gents. Get ready...should be really really fun this time. The crank was FINE on the RB28 and I'm going to be putting all this back together soon enough!!! STAY TUNED!
  • Like 3
Well this popped up for sale about 6 hours from me for a very fair price. I like that it's still pretty stock. It does have downpipe, full exhaust, and coilovers...but check out that stock airbox! (forgive me I've never seen one in person on the 10 or so R32's I have seen). I will keep this one stock and build the other chassis into a pretty healthy racecar.
  • Like 4
A lot of people replace the standard air filter setup but the stock airbox is good for around 400kw. My Racepace built 32R uses a stock airbox still. In fact i went from a K&N pod filter kit back to stock airbox.
Car looks good. From the engine bay shot, it also has a Nismo strut brace with the BMC stopper built in.
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
