ok well i lost my car keys 2 days ago. and ive pretty much given up looking for them... but i dont have a spare key and the car is stuck at my cousins house
what can i do? can i get a key moulded to my current lock? or do i have to get a new one???
this has been pissing me off all weekend! does anyone have any ideas?
First get into the car, maybe a coathanger ? Then remove one of the doorlocks and take it to a locksmith on Monday.
He will be able to dismantle the lock and measure the pins. From this he will be able to make you a key. If it works, get several made !
Hide a spare key somewhere under the car where it cannot be seen. Or maybe bolt a spare key behind the numberplate or something.
Then one day when you loose your keys at 4AM, out in the middle of nowhere, in the pissing rain, with no money in your pocket, you will be o/k !
i know what its like. I sorta did the same thing. Was on holiday in Byron Bay and couldnt find the keys anywhere on the day we were meant to leave.
Lucky wrx's are easy to break into, so we managed to pack the car, go to the pub and forget about it.
Found the keys 2 days later in one of the girls handbags.... felt stupid, but we got 2 extra days of holiday!
Originally posted by Dragon18
if you lose your keys that means u cant start your car anywayz coz
of the immobiliser and alaram hehe
hehe just do what my dad does (being the extra cautious Camry driver he is :D )
he's got a key and a spare remote for the security system tucked away up in one of the bumpers. It's tied up with heaps of wire so it can't come loose and it's in a sealed plastic bag so that no water or dirt gets in.. :D
Well I also have an alarm/immobiliser and steering wheel lock. Both front doorlocks are disconnected so a thief cannot twist the locks around with a large screwdriver. That is how I lost my last car.
If I lose my keys, or the battery in the remote goes flat, my system is as follows.
Get the spare key from under the car, get into the rear boot. Inside the boot I have a spre remote for the alarm to gain entry, and a spare key for the steering wheel lock.
Just make sure the battery is replaced every now and then! It would be so frustrating to find the spare remote wasnt working. I was stuck for a while in Chadstone late one night after a movie when my immobiliser battery died... I pulled the battery out and twisted it around and luckily it somehow had enough power to work so I could start the car.
Hide a spare key ...  behind the numberplate or something.
I did that once. One problem - the screwdriver to undo the number plate was in the boot - which required the key behind number plate to open it!!!!!
With regard to the alams and immobilisers - most immobilisers simply intercept the wire to the starter motor, they don't actually disable the car (all the lights on the panel light up, just the starter won't work. Solution (for manuals only) - kick start down a hill!!!! And the alarm should have some means to disable it without the module.
Bolting the key behind the numberplate was used as an example to get people thinking, but I have actually done this myself though.
If you use a stainless steel screw and a brass nut, with a shakeprook star washer, it will not vibrate loose. It will not rust up either. By twisting the key, the nut can be loosened quite easily. Try it and see ! Or maybe a brass wing nut.
Another way is to attatch a long piece of stiff wire to the key and poke the key down inside a chasis rail, gearbox crossmember, behind the front grille, inside a hollow towbar, or something. If you can feel the end of the wire with your fingers, then pull the whole lot out.
Use your imagination. Suerly you can find a place that does not require a full 250 piece toolset on a trolly to get at the key. Jeeeeez
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
