Hi All
After some 'hektic' pinging problems, and 'hektic' blow by my engine finally blew about a week ago.
I dont know how many cylinders are gone but it doesnt go very fast anymore :) haha!
So I ordered in some parts and they all arrived today!!!!
- Neo RB25DET
- Hi-Flowed VL Turbo (I think they are T04's? Correct me if I'm wrong)
- EMS Computer (Will be tuned by V Rigoli)
- Powerdigger Electronic Boost Controller
Already have mods:
- Hybrid 600 x 300 x 76 FMIC
- 3" Exhaust
- Pod Filter
Hoping for somewhere around 200 - 220kw @ the wheels at @ 14psi
https://www.sau.com.au/forums/topic/44775-neo-powered-r33/
good luck with the build....sounds like there could have been cheaper options tho? why the neo engine for example, they could just rebuild what you already had :confused: Same with EMS, why not just use a PowerFC?
https://www.sau.com.au/forums/topic/44775-neo-powered-r33/#findComment-914913
I chose the EMS and 34 Engine because I have the means too.
My uncle is owner of Stevens Prestige at Lansvale he had a Neo 'Lying around' the workshop so to speak.
I chose EMS because thats what he recommended, he uses it on his heavily modified GTR, which will be out soon :)
Can you tell me whats wrong (or good) with EMS? (seriously because I just dont know about aftermarket ECU's)
https://www.sau.com.au/forums/topic/44775-neo-powered-r33/#findComment-915032
I "know" a guy up here that did a Neo into a 33 and he said it was a nightmare to fit the 33 engine wiring harness to a Neo. I'll admit this guy was no brain surgeon but there is plenty of differences apparently, not just engine but body related as well.
DezertEagle, I asume you don't have the Neo harness? Thats why you chose aftermarket?
Anyway, good luck with it!
https://www.sau.com.au/forums/topic/44775-neo-powered-r33/#findComment-915078
Yeh my uncle told me it wouldnt work, and so I'm going aftermarket computer :P He has done many a transplant in the past (they might as well do one everyday) so they have alot of experience
https://www.sau.com.au/forums/topic/44775-neo-powered-r33/#findComment-915223
Sorry I was talking about the big car his uncles got that will be out soon, he mentions it in post 4
Wow you know about it?!
Yeh I dont know much about cars really haha, but he said he expects like 700kw?
Just know how to drive them and basic things to make them go fast, I just take it to him and he does what he reckons is best..... of course I get 'Family rates' (better then mates rates I guess) thats why I'm doing all this
https://www.sau.com.au/forums/topic/44775-neo-powered-r33/#findComment-915633
hey guys
well i just got my car back from the workshop not long ago i also did the rb25det neo converstion into my r33 let me tell you it was a headache. its getting dynoed this weekend,i also use the ems stinger and ive had no problems with it all though a lot of other workshops say that its utter crap and i should get a power fc
but the stinger is not bad.
anyways good luck hope every thing goes well
ibz23q
https://www.sau.com.au/forums/topic/44775-neo-powered-r33/#findComment-923083
    • Definitely the stroker kit. once you mention you have a RB28 everyone will assume you will flog them and hopefully won't start asking about support mods. Anyone will be too scared to race you, except maybe the RB30 boys
    • Just a quick update: I decided to go ahead with the de-cat for now. The exhaust shop inspected the catalytic converter and said it was in good condition. I took a look myself, and it does not appear broken nor clogged. After the de-cat, the car feels more responsive and smoother. The shop also reinstalled the exhaust temperature sensor into the de-cat pipe, and now the warning light no longer comes on, even when driving hard. The only thing that’s bugging me is the tinny, “can-like” sound the exhaust makes now (similar to having a hole in the muffler). The shop suggested that I might need to replace the muffler. I'll have to think on what to do next.
    • I want to start upgrading but don't have the budget to drop 15k at once, if i was to do one first which would be better and why?
    • Yuh. It is very rare for a single turbo to throw ceramic into the engine. Quite common on GTRs. As I posted above. Mine did destroy the O2 sensor on the way out though! Plastic compressor is fine with the temperature. It's not some flimsy PE/PET/PP thermoplastic. It's a thermoset resin with reinforcing material in it (a composite, as posted by @Lithium above). The compressor never sees much more than 100°C because it's never boosting very high. If you boost it high enough to make a lot of temperature, then the turbine will depart the scene and stop the party anyway.
    • From what I understand, it's a ceramic turbine and a plastic compressor (not sure how it doesn't melt then lol) I heard the series 2 r34 gtt has a metal turbine but I doubt that. @GTSBoy When you blew your standard neo turbo it didn't cause damage from memory just the turbine ended up in the cat?
