So I have to replace my hand brake unit soon and I have it plus the 40cm of cable trailing on it, but am unsure of how to install. Any tips on this?
And importantly, can I install this purely through the cabin, or do I need to jack up the car and get under it?
thanks
https://www.sau.com.au/forums/topic/448005-installing-std-hand-brake-question/
Wut? Your car has no handbrake in it at the moment and your just going to hook up the lever without checking the rest of it over?
Being that its brakes (I know handbrake is nowhere near as vital as normal brakes) I'd be checking every inch of it if it hasnt been working/used in ages. Wouldnt want something to fail and watch your car roll away....... Well I know I wouldnt.
Just Jack it up, its not that much effort for piece of mind. If it were me I'd pull the back wheels off and adjust the brake shoes as well
The car does have a handbrake. Its modified to be a spin turn type for drift but I don't drift anymore and am replacing it with a wrecker item so it works like standard again.
Looks like I'll be jacking the car up then. I was hoping I could get away with not having to; its a PITA.
Not as much of a pain in the ass as having your car roll away when you park it on a hill and your handbrake fails. I know it sounds like I'm thinking 'worst case scenario' but these things do happen, and if it does your not going to think it was a pain in the ass to jack the car up then. For the sake of an hours looking over everything, its worth it in the long run
As a postscript to this I checked under the car and the connection I need to get at is directly above the tailshaft and I'm not sure how I can unhook it (its a pressed metal connection, not bolts) so I might just get my mechanic to deal with it
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
