Having a garage clean out!
All prices ono!
everything located 15 mins from Geelong (3222), would be willing to send if buyer includes postage fee! postage quotes can be obtained through auspost website!
S1 R33 cluster 58xxxx kms $150
4x114.3 wheels plus excellent tyres (road worthy tyres) 80% tread all round. (stock 180sx wheels) $150 ono
SR20 water pump $40
HIDs hi/lo beam, BRAND NEW never used! 55w, 12v,12000k, H4 - $50!!! ($80-$120 new)
HIDs H7 6000k, 35w, 12v, also brand new never used! - $40 worth 80 new.
SAAS gauges - $30 each or $50 for both (includes wires and a temp sensor) OIL TEMP + WATER TEMP
DRIFT gauges - water temp and volts + wires plugs etc $45 each or $80 for both
R33 S2 front bar fog + indicator lights (I think its passenger side) $40
SCA pod filter with flex hose + clamps (good for NA cars) $20
R33 rear tail lights $80 pair
19' osaka 114.3X5 (ford nissan) 2 rims 1 tyre $100 tyre is -245/35
R34 GTT stock standard catylic convertor - $20
Prices are ono pickup is from Drysdale 3222 or can send via buyers request.
Contact - Daniel 0466 103 384 txt or call.
  • 1 month later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
