Hi, having recently purchased a completely stock R34 im looking into doing some handling upgrades, nothing crazy just general street use and a trip to the track twice a year. However that being said I don't want some sloppy or something that's going to make it damn near uncomfortable. Ive looked at getting coil-overs with lower spring rates but is that really the best option. Due to the fact that I like taking corners pretty fast it would seem like a good option, but could I achieve similar performance with lowered performance spring and shocks and upgraded front and rear strut braces and a sway bar down low? The car will only be making around the low 300hp at the wheels and its got decent grip and fairly wide tires. In short could a more street-able option be to ugrades springs and shocks and put in braces all round then go for coil-overs, but still be able to level with coil-over performance in general street track use.
Thanks all :)
https://www.sau.com.au/forums/topic/448058-r34-handling-upgrades/
Hey Chids34 - I also recently got my hands on a stock 34, I have been hunting around now for some decent suspension for 2 reasons - 1.) I hate how high it is, and 2.) I would like some better performance.
Basically I walked into petters and got a quote of $1400 for their fully adjustable fully warranted suspension setup, or $2300 installed plus a 1500km set-up time where in that 1500km you could bring the car back anytime and have them alter the ride stiffer/softer, lower/higher etc. Also everything they do is warranted for 3 years.
I've heard from GTR owners that BC coil overs are a fantastic option as they don't apparently sacrifice any comfortability for street use and they are around $1100 on ebay.
I've also seen nolathane bush kits for the 33's and 34's on ebay from $80-$300, depending on how much you want to replace.
Let us know if you decided on something and how it feels/handles on the road, also would be keen to see ride height.
The guys that think those BC's have any value in them whatso ever have rocks in their head. May aswell put some railway sleepers in. Might do a better job.
- Set of mid-range coilovers, such as MCA, Shockworks (I have these in 8/6) or get onto sydney kid for a bilstein setup.
- Sway bars front and rear
- Rear camber and front castor arms
- Adjustable front camber bushes
- Hicas lock bar
- Replace every other bush you can afford
Alignment, then sorted.
Edited by owen1r
- Hicas lock bar
The above is the gospel according to us.
Thanks for the info, but to answer my actual question can I achieve the same results without coilovers? Going the coilover way is great and all but I was asking if similar results can be achieved without them, not whether or not I should use them because everyone else does, which yes would suggest they have there advantages but I'd like to know anyway.
Thanks J
Everything is a coilover. The standard suspension is technically a coilover design. What I think you mean is an adjustable coilover kit. The suspension needs to match the rest of the cars mods and its usage. Given you said you only wanted 220rwkw you may be able to get away with a cheap coilover set and still get what you want.
I personally take the 'do it once, do it properly' approach. Future you will probably thank you ;)
Everyone's a critic, until they actually use them, then their input is worth listening to. ;)
If you can't set up adjustable suspension you are better off with the Bilsteins.
  • Like 1
To the OP - if you're going to take the "do it once, do it right" approach then I suggest heading to pedders and just have a suss out of their stuff, but it is pricey. Otherwise theres not much info on the type of suspension people are running and feedback, perhaps a new thread should be started so people can tell us what gear they're running and what its like on the street/track, how easy it is to adjust, what settings they use how much they paid etc etc. Would be a handy thread!
Edited by vetter2769
I think people understand what I mean when I say, 'coilover' it clearly doesnt mean im putting the stock 'coilovers' back in, it more or less implies upgrading to a 'coilover' those that are bought aftermarket. And yes thankyou there is a difference I can get lowered springs and standard shocks, is it a coilover? technically if I sold it to someone would I call it a coilover? probs not. And to be honest your not even answering the question your just being obtuse, is the question should I put coilovers in? no its not.
Thanks for your feedback.
I've been in a few cars with them. They're terrible. Isn't that enough?
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
