Hi All,
Need help regarding my OS Giken R3C clutch in my bnr34. The pedal used to engage the clutch about half way and now its a few centimetres of the floor.
Have taken out the clutch as I thought it was burnt, but it is not. Doesn't seem like my slave/master cylinder is leaking as the oil is still quite full. Have also tried to adjust the pedal with no luck. Clutch still seems like it holds power.
Any recommendations? Thanks guys
Master cylinders don't tend to leak when they are stuffed, they bypass the seal.
You can try clamping the line and pushing on the pedal and seeing what happens. It shouldn't move of master is good.
I hope you tried bleeding it before you pulled the clutch out! It's not like it's easy to whip the clutch out of a gtr!
Edited by Ben C34
