Thought id give it a try, been thinking about it for months now and i just cant seem to find the info i need, so i decided to start a build thread.
Firstly im making a custom baffled catch tank that 2 scavenge kits will be hooked up to from my turbo down pipe creating vac esp at high rpm. I know there must be no back pressure for it to work correctly and luckily i have a free flow all the way through.
On the catch tank will be a vac relief valve to relieve at a certain vacuum (if at high revs it draws too much vacuum), a 1way/check valve to get rid of any positive pressure in the system and a boost/vac gauge to see whats happening.
I know there are easier ways to get vac on a catch tank but i dont want any blow by gasses sucked back into my intake system.
Let me know what you guys think
https://www.sau.com.au/forums/topic/448104-rb26det-exhaust-scavenge-build/
won't that pressurise the catch can and therefore the head (through the cam cover breathers) when under high load/rpm due to exhaust backpressure?
I know you said you have no back pressure, but have you actually put a gauge on it? I'd be suprised if you hadless than 2psi back pressure at full boost. Depends on what turbo/exhaust you are running, but I'd be very suprised if you had 0 back pressure
The only exhaust scavenge setups I have seen work are on race cars that run no mufflers. The moment you have a post-turbo restriction of any kind, you end up with a higher than atmospheric pressure inside your exhaust (after the turbo).
Remember you are trying to produce a vacuum, not just aid flow from what is already a high exhaust pressure (such as venturi style wastegate scavenging).
Using a 2 stage catch can setup that draws from a venturi on your Intake just before your turbo will produce a vacuum in the engine. Your first catch can had better return to sump though, or your vacuumed up oil vapour will quickly make a mess on the inside of your intake piping.
Thanks for the comments. Seems like there are some issues i overlooked.. As 89CAL stated, its likely to have slightly positive pressure at high rpm/boost :verymad:. Starting to think along the lines of a vac pump or pre turbo vac line that draws from my sump (the highest point of sump on drivers side). In my head it should kind of promote faster oil drain from the head down to the sump, instead of drawing out the cam breathers decreasing oil return? Making more sense?
Pre turbo vac source would have to have sufficient baffleing/oil air separation though.
Might even work using my rear turbo oil drain as a place to introduce the vacuum to (no longer in use, rb26det). Then again as far as i understand the passenger side of the motor has a natural vac at rpm, which wont help me at all.
Any problems you guys see with this please give me a shout as i have to make a plan by the end of the week, powercruise is getting closer
Thanks again
Not so much a problem, more so a question. Are you over thinking things?
I know your probably trying to do something different to find a new way to do things, but wouldn't a baffled catch can with sump drain and vac from the intake work fine?
There is a way to ensure the exhaust scavenge system works, even though it's pointless, is to put the venturi pretty much at the end of the exhaust, the last 300 mm or so where there can't be back pressure.
I sure have been over thinking things it seems. And yea i kinda did want to do something different but this car is draining the life out of my wallet now so im simplifying it.
Just going to get vac from my intake pipe and route it to my block somewhere with an air/oil separator in between. Possibly another intake pipe - air/oil separator - cam cover breathers.
Options i have on my block are; 2nd turbo oil return, dip stick or unused -10an sump bungs (came with the rips high cap sump, high as possible and at the front drivers side).
Thing is i just fully rebuilt and on my last hard pull through all the gears on high boost it spat some oil out the breather on the cam covers at the top of 4th. I think its mainly because im only running a filter on one side and the other goes to the stock place (plenum side just above fuel rail) that only sees vac at idle. I will be getting some mines cam cover baffles too and see how that goes.
Anyways cheers
The best solution you have is to use a catch 3 hose catch can (each cam cover, and the intake), and a return to sump via the -10 RIPS sump return. Hi Octane have the catch can you need to complete this setup. Not cheap though.
The return to sump via the 2nd turbo return on an RB26 block works great too. Nismo pioneered this of course. You can improve on it by drawing the intake connection through a second catch can and then to the intake. Useful if you are really trying to isolate all moisture from your crank case fumes.
  • Like 1
  • 1 year later...
Read the oil control issue thread, and just do a catch can setup like that.
An exhaust scavenge setup can work and has been shown to work, usually on N/A cars though, but for your setup, it's probably not required and over the top.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
