livewire (Kevin) - NSW - V-SPEC
KPCresta (Gavin) - WA Non V-SPEC
Chris_H (Chris) - WA - V-SPEC
32rulz (Ken) - Hong Kong - V-SPEC
smalls (Will) - UK
GTRLM1 (gtr.co.uk forum) - UK
ab20000 - UK - V-SPEC
torra (Jim) - South Shields, UK - Non V-SPEC
TheWatch (Marco) - Glauchau, Germany - Non V-SPEC
Bluzzer (Nicolai) - Denmark V-SPEC
10 found so far! We are doing well! And all of them look so good which is great to see.
Hey guys!!!
I´m Stefan from Freistadt in Austria. TheWatch (Marco) invited me to look at this Forum because of this thread. I also own a R33 GTR LM V-Spec. It´s been imported from Japan to UK in 2012 and than shipped to Austria. The mileage is 46000Kilometers, Body is stock and in good condition with new paint. The engine is tuned with HKS GT2530 Turbos, Titan exhaust 4", Hks Cams and cam gears, Greddy intake plenum, Apexi Power FC and some other specs. It puts out 535Hp at 1.5bar.
I think it´s good to find out where some rare cars are.
Kind regards! Stefan
smalls (Will) - UK
Computer3001 (Stefan) - Freistadt, Austria V-SPEC
Hello
Here from Malmoe in sweden
have owned my LM for 7,5 years now, and have done some work with it during that period ...
and it is a V-SPEC
here is a few pics
[/url]">http://95E2BF0E-6E47-4FC8-8EBF-4FBB57894DA6_zps
Edited by Ricky R33LM
  • Like 1
smalls (Will) - UK - Non V-SPEC
ab20000 (Matt) - UK - V-SPEC
not registered yet (Dean) - UK
not registered yet (Danny) - UK
Talked to Will some days ago, he has a Non V-SPEC model. Also talked to Dean and told him to participate here...
Found Danny's car and this Video in the thread of his son on gt-r.co.uk forum, which was last updated 10/2013, so i believe he still owns it.
https://www.youtube.com/watch?v=RF0nv9Pd7IU
Believe there is one or two more to find in the UK...
cheers.
Edited by TheWatch
cheers.
Hi, this was Dannys car which i now own....it was stood in a shed for 5 years until i took it off his hands...
Ohhh, i'm sorry Jim, Danny looked like a collector to me, didn't expect he would sell it.
Ricky R33LM (Ricky) - Malmoe, Sweden - V-SPEC
Edited by TheWatch
I have know danny for a few years, he was co-owner of the Jap north east forum/ meets here in the UK,
I`m sure if he did not need to sell it he would still be the owner now.....
it was first brought to the UK in 1996 the disaster as the engine only lasted a few hours then Bang!....wrong fuel map!
smalls (Will) - UK Non V-SPEC
Not registered yet (Dean) - UK
Stefan got chopped off the list accidentally, amended. 13 of 98!
  • 4 weeks later...
This is great guys, you know I'm actually really interested in how many of them are V-Specs and how many are standard GT-Rs.
I heard there's only 14 V-specs but that's not looking likely so far!
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
    • nah no problems with bearings or hubs.  just the water pump leak and my AC death
