  • 2 months later...
Hey guys,
Had a look through this thread the other night, i don't have an LM but it is good to see a register like this. I came across this on J-Spec imports this morning. I'm not sure how accurate there auction today cars are but I thought you might be interested.
Regards,
DW
  • 2 months later...
  • 1 month later...
  • 2 months later...
Hi everyone, have not been here for a while but currently running the Spool 2.8 Crank (1500bhp) with ACL Race bearings in with 2 new Greddy T67 Turbo Cores (550bhp each)...
its been a long time coming but hope to get it on the Dyno and see how things turnout!!
http://i21.servimg.com/u/f21/17/90/98/87/lm_gtr10.jpg
http://i21.servimg.com/u/f21/17/90/98/87/lm110.jpg
Thanks!
Here is an update on the spec list:
1996 Nissan Skyline R33 GTR Le-Mans Limited Edition.
Racing Blue 1 of 98 Made...
ENGINE Spec... 41,000km on the Clocks
2.8 HKS Stroker kit
Twin Trust T67 Turbos (New) Cores (550bhp each)
Cylinder head extensive ported & polished
N1 Bored out Block 87mm
Spool Bilited 1500bhp balanced Crank (New)
ATI Performance Super Harmonic Damper
ACL racing bearings (New)
Jun oil pump
Trust Big sump extension
Uprated Water Pump
HKS 2.0MM steel head gasket
HKS head bolt kit
HKS Intercooler 150mm
HKS hard pipes
HKS Elbows
HKS actuators
HKS iridium plugs
HKS 50mm external waste gate
Screamer pipe
Greddy plenum
Oil cooler filter relocation kit
SPEC-R custom breather/washer tank
Custom built exhaust system 4"
Pro alloy aluminium radiator
Tomei cam pulleys (New)
Greddy timing belt (New)
Clear cam cover
Greddy oil cap
Heat wrap
Turbo blankets
Greddy Air Diversion Plate
Engine plaque limited edition midnight club
Password JDM washers for engine bay purple
Could be more what i have missed out....
BRAKES & SUSPENSION...
Kawasaki Coilovers
K-sport 8 pot front Brake Kit 356mm with EBC Bluestuff Front Pads
DBA 4000 Vented rear brake disks (New) With standard Brembos
DRIVETRAIN...
HKS 6 Speed dog box
OS Giken Triple plate clutch (New)
Trust rear Diff 2 way
Quaife Heilix Front Diff (New)
FUEL SYSTEM...
HKS - Fuel Injectors 1000CC
Aeromotive fuel pressure regulator
Twin in tank Tomei fuel pumps
Greddy fuel rail
Aquamist water injection kit
INTERIOR...
Nismo 320KM-MPH White
Apexi Gauges White X6
Oil Temp
Oil Press
Water Temp
Boost
Ext. Temp
Fuel Press
Turbo smart 2 Boost controller
AEM Air/Fuel Gauge
momo steering wheel
Nismo gear knob
Nissan upgrade option, Momo Airbag/ Steering wheel, Nismo White Dials, Pioneer Carriozerra stereo and stacker and speakers
ECU...
HKS FCON V-PRO & Map Sensor
Road map done By Tweenierob (RIP)
WHEELS & TYRES...
Federal 595 RS-R Semi slicks (New)
Rota grids alloys
Rays Wheel Nuts Blue
Edited by torra
  • 2 months later...
  • 4 weeks later...
Anyone else seen this currently on carsales?
Is it one of the registered ones here?
http://carsales.mobi/cars/details/1996-Nissan-Skyline-GT-R-BCNR33/SSE-AD-3429307
This car came up again on Monday 4th Jan. It was listed from QLD, in the next suburb from me. http://www.carsales.com.au/private/details/_/SSE-AD-3429307
I called Tuesday, only to get a response car sold and already paid for (I suggested I could view the car within the hour,), and seller would not listen to any ideas about letting me view it anyway.
Same carsales advert number (#3429307).
Sounds interesting !
I have all the details. If anyone is interested in the photos/seller details from the add (including VIN plate) PM me.
  • Like 1
livewire (Kevin) - NSW - V-SPEC
KPCresta (Gavin) - WA Non V-SPEC
Pal (Eric) - WA - V-SPEC
32rulz (Ken) - Hong Kong - V-SPEC
smalls (Will) - UK Non V-SPEC
GTRLM1 (gtr.co.uk forum) - UK
ab20000 - UK - V-SPEC
torra (Jim) - South Shields, UK - Non V-SPEC
TheWatch (Marco) - Glauchau, Germany - Non V-SPEC
Bluzzer (Nicolai) - Denmark V-SPEC
Computer3001 (Stefan) - Freistadt, Austria V-SPEC
Ricky R33LM (Ricky) - Malmoe, Sweden - V-SPEC
Not registered yet (Dean) - UK
.R33. (Daniel) - QLD
updated list
Edited by Pal
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
