So to begin im sorry if there is other related threads to this topic but im slightly confused and cant seem to get a straight up answer..
Im sure most of you guys have heard or seen these "WIFI Interface adapters" you can buy to read your cars Diagnostics through your smart phone? (iphone/Android/Ipad etc)
Im keen to give it a go and have a little play around with one but however im not sure what Consult port my 96' R33 GTR S2 has, its a rectangular gray plug but however it looks nothing like the ones i am seeing for sale on ebay as they are all OBDII - OBD2.
Has anyone purchased a wifi adapter for a skyline?? an whats the feedback like??
I understand they arnt exactly "professional" but it sure beats spending $300 -$500 for like a Blitz R-vit or something similar.
https://www.sau.com.au/forums/topic/448179-wifi-diagnostic-ports/
Amoxicillin 500mg fluoxetine hydrochloride purchase: sarafem 10 mg for pms fluoxetine e91
Because scabies mites don't live long away from the body, it isn't important to dry clean the entire wardrobe; however are are required to run all linen, bedding and clothes through the dryer on high before use to kill the scabies mites. dutasteride 500 mcg: dutasteride hair loss 2011 dutasteride 2.5mg hair loss
Concluding all the above we can only say that if using antibiotics as well as any other drugs you should strongly consider the possibilities of unwanted effects and not abuse the drug. buy trazodone hydrochloride: trazodone online trazodone 433
Amoxil should be taken with care. bupropion 150mg sr: can you get high from bupropion xl 150 mg can i buy zyban online
Tetracycline prevents the growth and spread of bacteria. thuoc atorlip 10: atorlip 10 mg side effect atorlip de 40 mg
3) Exercise DAILY, Clenbuterol helps you help yourselfвЦ it is not some magic wonder pill that just makes you skinny, the day they release that magic pill we will ALL look like Brad Pitt/Angelena Jolie.
fluoxetine 5ht2c receptors.
online pharmacy dutasteride.
fluoxetine 40 mg weight loss.
something like this? https://www.kickstarter.com/projects/obdsol/obdlink-mx-wifi-a-wireless-gateway-to-vehicle-obd
It'd be mega cool to have this! only problem is, far as I'm aware they don't make them for Nissan's, my guess is because some skylines are banned over there...
You have a consult port that uses the consult interface. It is not obd2 . It's consult.
They won't work.
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
