So to begin im sorry if there is other related threads to this topic but im slightly confused and cant seem to get a straight up answer..
Im sure most of you guys have heard or seen these "WIFI Interface adapters" you can buy to read your cars Diagnostics through your smart phone? (iphone/Android/Ipad etc)
Im keen to give it a go and have a little play around with one but however im not sure what Consult port my 96' R33 GTR S2 has, its a rectangular gray plug but however it looks nothing like the ones i am seeing for sale on ebay as they are all OBDII - OBD2.
Has anyone purchased a wifi adapter for a skyline?? an whats the feedback like??
I understand they arnt exactly "professional" but it sure beats spending $300 -$500 for like a Blitz R-vit or something similar.
https://www.sau.com.au/forums/topic/448179-wifi-diagnostic-ports/
Amoxicillin 500mg fluoxetine hydrochloride purchase: sarafem 10 mg for pms fluoxetine e91
Because scabies mites don't live long away from the body, it isn't important to dry clean the entire wardrobe; however are are required to run all linen, bedding and clothes through the dryer on high before use to kill the scabies mites. dutasteride 500 mcg: dutasteride hair loss 2011 dutasteride 2.5mg hair loss
Concluding all the above we can only say that if using antibiotics as well as any other drugs you should strongly consider the possibilities of unwanted effects and not abuse the drug. buy trazodone hydrochloride: trazodone online trazodone 433
Amoxil should be taken with care. bupropion 150mg sr: can you get high from bupropion xl 150 mg can i buy zyban online
Tetracycline prevents the growth and spread of bacteria. thuoc atorlip 10: atorlip 10 mg side effect atorlip de 40 mg
3) Exercise DAILY, Clenbuterol helps you help yourselfвЦ it is not some magic wonder pill that just makes you skinny, the day they release that magic pill we will ALL look like Brad Pitt/Angelena Jolie.
fluoxetine 5ht2c receptors.
online pharmacy dutasteride.
fluoxetine 40 mg weight loss.
something like this? https://www.kickstarter.com/projects/obdsol/obdlink-mx-wifi-a-wireless-gateway-to-vehicle-obd
It'd be mega cool to have this! only problem is, far as I'm aware they don't make them for Nissan's, my guess is because some skylines are banned over there...
You have a consult port that uses the consult interface. It is not obd2 . It's consult.
They won't work.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
