M35 Gaskets - 3.5L
Ignigknot
 Share
Hi All,
Just picked up a 2006 Axis 3.5l and noticed oil in the spark plug area, been informed that the required gaskets / seals will take 3 weeks from Japan. Anyone here know if local 350z/Maxima parts are in most cases compatible?
Cheers.
Yes, 350z parts are fine to use, I don't know about the fwd maxima.
Now, the only way to fix the plug tube leak is to buy a whole plastic cam cover, which is a pretty expensive fix. If you not talking about a lot of oil, and it isn't coming from the outside of the valve cover (that seal is replaceable), then it's best just to leave it alone. It doesn't effect any performance, as it's an insulator.
Thanks guys - appreciate the guidance!
And make sure you get parts reference from a 2003 350z
They got some engine changes in 2006 I seem to recall.
Just so I am clear on this - are you saying that the 2003 350z engine is the best match as the local 2006 350z engine changes mean it differs from the 2006 Stagea set up?
Thanks again.
All 3.5 stageas got the same motor as a 2003 350z
2006 350z received the "revup" motor, that would be 95% similar, but had some changes.
Models after that got the vq35hr which is significantly different.
You could use your vin to check parts, that way you know they are correct. EPCdata then Amayama. ;)
As Alex said, the plug tube gaskets are not replaceable, you will need the entire rocker cover which will set you back $250 odd. As the oil only weeps in, and the oil is an insulator, you have no problems if you ignore it.
 Share
    • Think I found another reason to buy the Q50 rather than the skyline import, seems that unless you get the 400r the other models such as the GT miss out on the decent brakes and don't have the flappy paddles on the steering wheel to change gears. Its my day off work today and the Q50 listed @ the dealer in Brisbane that I mentioned in my 1st post looks like it sold as its listed as no longer available... Would have checked it out but can understand why it sold as it was a bargain price.
    • omfg.... That shopping list game. I'd hoped I'd never see it again.
    • There are fixes for this. In industry we use compressed air for everything. It is frequently wet, and many things cannot tolerate it. So there are various forms of driers available that you can install. The simplest option for something like this would be a dessicant drier. Much cheaper to replace some silica gel than actuator cylinders.
    • That's a solid update mate, well done at WA FOS. You may already know this, but the actuators on the paddle shift are a service item and are sadly not that reliable. As I understand it they collect water from the compressor (condensation) which then rusts the bores/pistons in the actuators. A mate of mine had no end of trouble with them in one if his circuit cars, apparently it's a 'known issue'. Buy a couple of spares at great expense to ensure you never have any problems with the ones you've got! Any clues about what the new WTAC rules might be? While faster cars are cool the Pro class arms race has got to the point where you wouldn't even bother entering without a $1m budget and even then I don't think you'd win.
    • https://nissan.epc-data.com/skyline/er34/3945-rb25det/trans/317/31940N/ The pictures of the part you're talking about is clearly not just one solenoid. You can see another picture of it here: https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/RE5R01A/product/9305/ The 4 speed automatic in the GTT is Nissan corporate stuff. You can search up similar jobs done on a Frontier or Pathfinder with a RE4R01B to get an idea for what the internals are going to look like and the procedure like this:
