Kanaric Posted September 2, 2014 Share Posted September 2, 2014 Never had a problem like this before in any car. Basically the car was going into limp mode and intermittent loss of power above 3000 RPM. TL;DR the MAF was getting the filer's oil on it causing it to lose functionality, had to clean the MAF often with MAF cleaner and the car ran fine for a few days. I live in vegas where it gets 40+ degrees regularly so maybe that causes the oil to become more fluid and causes this problem. It's just weird. I've NEVER had this problem before with a K&N filter. Had a WRX and 350Z both with oiled filters like this and neither of them had an issue. I guess this is a "cool story bro" post but it's just something ridiculous to me so I felt the need the post it. Link to comment https://www.sau.com.au/forums/topic/448213-strange-problem-easy-solution-kn-filter-maf-issue/ Share on other sites More sharing options...
Dose Pipe Sutututu Posted September 2, 2014 Share Posted September 2, 2014 Common issue with oiled filters, another reason why I just buy cheap filters and replace them yearly. Link to comment https://www.sau.com.au/forums/topic/448213-strange-problem-easy-solution-kn-filter-maf-issue/#findComment-7381043 Share on other sites More sharing options...
Ben C34 Posted September 2, 2014 Share Posted September 2, 2014 Or put the correct amount of oil (not much) onto them. Heaps of people use them no worries. Link to comment https://www.sau.com.au/forums/topic/448213-strange-problem-easy-solution-kn-filter-maf-issue/#findComment-7381066 Share on other sites More sharing options...
Kanaric Posted September 2, 2014 Author Share Posted September 2, 2014 (edited) Or put the correct amount of oil (not much) onto them. Heaps of people use them no worries. This was out of box, didn't even put anything on it. Is there anything I can use to reduce the amount of oil on there? Edited September 2, 2014 by Kanaric Link to comment https://www.sau.com.au/forums/topic/448213-strange-problem-easy-solution-kn-filter-maf-issue/#findComment-7381113 Share on other sites More sharing options...
scotty nm35 Posted September 2, 2014 Share Posted September 2, 2014 This was out of box, didn't even put anything on it. Is there anything I can use to reduce the amount of oil on there? Yes, you can bin the crap and use a decent cotton element, like Blitz/Greddy etc. Even a paper element would be better than the K+N. Link to comment https://www.sau.com.au/forums/topic/448213-strange-problem-easy-solution-kn-filter-maf-issue/#findComment-7381119 Share on other sites More sharing options...
Kanaric Posted September 2, 2014 Author Share Posted September 2, 2014 Yes, you can bin the crap and use a decent cotton element, like Blitz/Greddy etc. Even a paper element would be better than the K+N. lmao, ok. Link to comment https://www.sau.com.au/forums/topic/448213-strange-problem-easy-solution-kn-filter-maf-issue/#findComment-7381133 Share on other sites More sharing options...
Cassbo Posted September 3, 2014 Share Posted September 3, 2014 K&N allegedly do extensive testing on their oil and filters against MAF sensors. If you believe that the filter is the cause of the problem, contact them for an explanation or refund. http://www.knfilters.com/MAF/massair.htm I've had a K&N filter in my R33 for years and I have never had a problem. Link to comment https://www.sau.com.au/forums/topic/448213-strange-problem-easy-solution-kn-filter-maf-issue/#findComment-7381161 Share on other sites More sharing options...
scotty nm35 Posted September 3, 2014 Share Posted September 3, 2014 Should I contact them to replace all the AFM's I have blown from running them, and all the customer's ones? I am sure they would love that email. lol. Link to comment https://www.sau.com.au/forums/topic/448213-strange-problem-easy-solution-kn-filter-maf-issue/#findComment-7381164 Share on other sites More sharing options...
Ben C34 Posted September 3, 2014 Share Posted September 3, 2014 Should I contact them to replace all the AFM's I have blown from running them, and all the customer's ones? I am sure they would love that email. lol. Yes. If you have a problem caused by an unsuitable item it is their responsibility to rectify it. Just email them. How hard could it be? Link to comment https://www.sau.com.au/forums/topic/448213-strange-problem-easy-solution-kn-filter-maf-issue/#findComment-7381173 Share on other sites More sharing options...
scotty nm35 Posted September 3, 2014 Share Posted September 3, 2014 Farkem. No way to prove they are at fault. The issue isn't the oil on the hotwire, it is the dust that sticks to the oil and insulates it from the airflow. Link to comment https://www.sau.com.au/forums/topic/448213-strange-problem-easy-solution-kn-filter-maf-issue/#findComment-7381175 Share on other sites More sharing options...
Ben C34 Posted September 3, 2014 Share Posted September 3, 2014 Running the correct amount of dust through an engine stops the bores from glazing. Fact. 1 Link to comment https://www.sau.com.au/forums/topic/448213-strange-problem-easy-solution-kn-filter-maf-issue/#findComment-7381179 Share on other sites More sharing options...
scotty nm35 Posted September 3, 2014 Share Posted September 3, 2014 I thought sand was the correct thing to use for self honing. Link to comment https://www.sau.com.au/forums/topic/448213-strange-problem-easy-solution-kn-filter-maf-issue/#findComment-7381186 Share on other sites More sharing options...
GTSBoy Posted September 3, 2014 Share Posted September 3, 2014 Bon Ami is what I used to use. Link to comment https://www.sau.com.au/forums/topic/448213-strange-problem-easy-solution-kn-filter-maf-issue/#findComment-7381200 Share on other sites More sharing options...
wolverine Posted September 3, 2014 Share Posted September 3, 2014 I'm with Cassbo, no issues ever with correct oiling. Happy to use OEM or cotton filters too. I would still give the hot wire a tickle with contact cleaner regularly regardless. Link to comment https://www.sau.com.au/forums/topic/448213-strange-problem-easy-solution-kn-filter-maf-issue/#findComment-7381326 Share on other sites More sharing options...
