Saunsw Texikhana 26Th October
crashdown
 Share
To confirm the changes,
I am quite concerned actually, as all I have been doing over the last two texi events were skids and linking corners. How strict will these rules apply to suppress ‘induced power sliding’?
Sliding the rear end of the car around the cones, is acceptable. If it turns into drifting or burnouts then it become not acceptable.
As Duncan said, the rules are just a clarification of a motorkhana event. Insurance has asked us to reinforce those rules.
The first post will be modified with the changes.
Yeah it's not that easy to follow all the cones and course at speed
Sometimes it gets abit out of control and you end up spinning and frustrated and smoke it up alil
If that's not on might have to cancel
How strict are you's on it
3 warnings and no more or just get told to take it easy
Smoking the tyres to get to the next gate quickly is fine. Smoke until you can't see your car, not ok.
We can only run these events while we are insured by AASA. We don't make these rules, they do.
If you are clearly breaking the rules we will give you a couple of warnings. If the clerk of course feels that you've been warned and continue they we can ask you to leave. It is all about us keeping our insurance rating so we can continue to hold these events.
Fingers crossed, the motorsport gods have been angry and thus I have not had any car fun lately, if all goes well and the stars align I shall be there with bells on.
And its OK for the skids from this end as the MX5 cannot do epic helis.
  • Like 1
^^^What Eric says.
MX-5's do a fantastic job at this event; good car control and a level head is the way to win.
A texi is a technical car challenge, using your memory, an intimate understanding of your car's strengths and weaknesses. Any idiot can chuck a mad skid (see any episode of ACA for further details), only a talented DRIVER can master the texi.
No one is saying that you have to drive like Miss Daisy, but if we don't respect the rules of the event, all we'll have is stationary carpark events.
How hard will people whinge if that happens?
If you are just renewing cams they get them out quickly. I did mine last week and got the new sticker this week. But don't wait too long, no current sticker to verify then we can't let your enter. Sux but that's dam insurance rules again.
  • Like 1
Work has been cancelled for Sunday, so I'm entered. I need to renew my membership , I think it's overdue by a couple of months , is it okay to do this on the Day?
Yes, you can renew/join on the day, please bring cash as we don't have eftpos
Looking forward to Sunday.
Do we have any sup regs yet? Will the course just be decided and changed on the day?
Want to make sure my car isnt missing anything that you guys deem important as its my first event with the SAU
Bum. With such an attractive car in the first post to really show the style and finesse of the event it's hard to say no, but alas i'm working the nightshift before and after the event =-/
Might be the first one in 2-3 years that I miss?
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
