To confirm the changes,
I am quite concerned actually, as all I have been doing over the last two texi events were skids and linking corners. How strict will these rules apply to suppress ‘induced power sliding’?
Sliding the rear end of the car around the cones, is acceptable. If it turns into drifting or burnouts then it become not acceptable.
As Duncan said, the rules are just a clarification of a motorkhana event. Insurance has asked us to reinforce those rules.
The first post will be modified with the changes.
Yeah it's not that easy to follow all the cones and course at speed
Sometimes it gets abit out of control and you end up spinning and frustrated and smoke it up alil
If that's not on might have to cancel
How strict are you's on it
3 warnings and no more or just get told to take it easy
Smoking the tyres to get to the next gate quickly is fine. Smoke until you can't see your car, not ok.
We can only run these events while we are insured by AASA. We don't make these rules, they do.
If you are clearly breaking the rules we will give you a couple of warnings. If the clerk of course feels that you've been warned and continue they we can ask you to leave. It is all about us keeping our insurance rating so we can continue to hold these events.
Fingers crossed, the motorsport gods have been angry and thus I have not had any car fun lately, if all goes well and the stars align I shall be there with bells on.
And its OK for the skids from this end as the MX5 cannot do epic helis.
  • Like 1
^^^What Eric says.
MX-5's do a fantastic job at this event; good car control and a level head is the way to win.
A texi is a technical car challenge, using your memory, an intimate understanding of your car's strengths and weaknesses. Any idiot can chuck a mad skid (see any episode of ACA for further details), only a talented DRIVER can master the texi.
No one is saying that you have to drive like Miss Daisy, but if we don't respect the rules of the event, all we'll have is stationary carpark events.
How hard will people whinge if that happens?
If you are just renewing cams they get them out quickly. I did mine last week and got the new sticker this week. But don't wait too long, no current sticker to verify then we can't let your enter. Sux but that's dam insurance rules again.
  • Like 1
Work has been cancelled for Sunday, so I'm entered. I need to renew my membership , I think it's overdue by a couple of months , is it okay to do this on the Day?
Yes, you can renew/join on the day, please bring cash as we don't have eftpos
Looking forward to Sunday.
Do we have any sup regs yet? Will the course just be decided and changed on the day?
Want to make sure my car isnt missing anything that you guys deem important as its my first event with the SAU
Bum. With such an attractive car in the first post to really show the style and finesse of the event it's hard to say no, but alas i'm working the nightshift before and after the event =-/
Might be the first one in 2-3 years that I miss?
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
