Wrecking R32 GTS-T.
Main items listed below, however too many parts to list them all. If you need something, just ask as there is every chance i'll have it.
Also have a few other random parts from RB25 and RB26. See bottom of post.
Pickup from either Traralgon or Melbourne - Sth eastern suburbs.
Happy to post if buyer pays postage.
Can supply more info and better photos for anything on request.
PM, or call / SMS - Mike 0412 678 973
Front guards - Both LHS & RHS. Black. No dents or creases. $50 each
Rear bar (not inc reverse lights) $60
Boot lid $50
Headlights $80 each, or $150 pair
Rear lights $40 each, or $70 pair
Indicators - 1 x LHS clear, 1 x LHS orange, 1 x RHS smoke $50 each
Complete dash - has the bubble in the usual place. See pics. $100
Glove box/s $30
Center console/s $30
Speedo/gauge cluster 139xxx km's $80
Speedo surround (inc headlight switches etc) - one in standard black, one painted silver - see photos. $60 each
Kick panels LHS & RHS available $20 each
Steering wheel surround plastics $30
AC/Climate control unit $40
Plastic stereo surround - painted silver - cracked at bottom $20
Gearbox/manual conversion kit - everything except flywheel $750
Top mix racing seat - no rails. Set up in fixed position in R32. $80
Standard seats - driver and passenger - good condition $35 each
Standard radiator $80
Standard fan $20
R33 RB25 tailshaft $100
Standard RB26 turbos - excellent condition $250
RB26 airbox $60
More available that i have forgotten about. Just ask if you need anything in particular.
Prices on most things are negotiable. Happy to consider reasonable offers.
Mike - 0412 678 973
post-33046-0-78731800-1409816106_thumb.jpg post-33046-0-57055900-1409816198_thumb.jpg post-33046-0-99932000-1409818789_thumb.jpg
post-33046-0-22025200-1409818889_thumb.jpg post-33046-0-31316100-1409819347_thumb.jpg post-33046-0-60879800-1409819784_thumb.jpg
post-33046-0-23047500-1409819995_thumb.jpg post-33046-0-25775100-1409820120_thumb.jpg post-33046-0-77783400-1409820522_thumb.jpg
post-33046-0-08354700-1409820666_thumb.jpg post-33046-0-81143200-1409820773_thumb.jpg
Edited by xtra.5
Mate, I'm looking for the driver side rubber strip that goes between door card and the glass on the inside. If in good condition
Got it?
Got it?
Got it?
Do you mean the felt bit that is attached to the top of the door trim?
any updates mate? have you got this trim part?
Hey mate, ive got it but not in good condition. its not straight and wont provide a good seal against the window.
Manual conversion sold.
Drivers headlight and passenger rear light sold.
Boot lid and rear bar sold.
Still got plenty here.
Also have R32 RB20 ABS Tailshaft available $100
Hybrid (i think) front mount cooler $60
Interested in the:
Stock Seats
Clear indicator
Glove box (I hope this is the same as 4-doors)
Stereo surround
AC/Climate control
DIN brackets if you happen to have them
pick up SE burbs.
Interested in the:
Stock Seats
Clear indicator
Stereo surround
AC/Climate control
pick up SE burbs.
PM sent
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
