Wrecking R32 GTS-T.
Main items listed below, however too many parts to list them all. If you need something, just ask as there is every chance i'll have it.
Also have a few other random parts from RB25 and RB26. See bottom of post.
Pickup from either Traralgon or Melbourne - Sth eastern suburbs.
Happy to post if buyer pays postage.
Can supply more info and better photos for anything on request.
PM, or call / SMS - Mike 0412 678 973
Front guards - Both LHS & RHS. Black. No dents or creases. $50 each
Rear bar (not inc reverse lights) $60
Boot lid $50
Headlights $80 each, or $150 pair
Rear lights $40 each, or $70 pair
Indicators - 1 x LHS clear, 1 x LHS orange, 1 x RHS smoke $50 each
Complete dash - has the bubble in the usual place. See pics. $100
Glove box/s $30
Center console/s $30
Speedo/gauge cluster 139xxx km's $80
Speedo surround (inc headlight switches etc) - one in standard black, one painted silver - see photos. $60 each
Kick panels LHS & RHS available $20 each
Steering wheel surround plastics $30
AC/Climate control unit $40
Plastic stereo surround - painted silver - cracked at bottom $20
Gearbox/manual conversion kit - everything except flywheel $750
Top mix racing seat - no rails. Set up in fixed position in R32. $80
Standard seats - driver and passenger - good condition $35 each
Standard radiator $80
Standard fan $20
R33 RB25 tailshaft $100
Standard RB26 turbos - excellent condition $250
RB26 airbox $60
More available that i have forgotten about. Just ask if you need anything in particular.
Prices on most things are negotiable. Happy to consider reasonable offers.
Mike - 0412 678 973
post-33046-0-78731800-1409816106_thumb.jpg post-33046-0-57055900-1409816198_thumb.jpg post-33046-0-99932000-1409818789_thumb.jpg
post-33046-0-22025200-1409818889_thumb.jpg post-33046-0-31316100-1409819347_thumb.jpg post-33046-0-60879800-1409819784_thumb.jpg
post-33046-0-23047500-1409819995_thumb.jpg post-33046-0-25775100-1409820120_thumb.jpg post-33046-0-77783400-1409820522_thumb.jpg
post-33046-0-08354700-1409820666_thumb.jpg post-33046-0-81143200-1409820773_thumb.jpg
Edited by xtra.5
Mate, I'm looking for the driver side rubber strip that goes between door card and the glass on the inside. If in good condition
Got it?
Got it?
Got it?
Do you mean the felt bit that is attached to the top of the door trim?
any updates mate? have you got this trim part?
Hey mate, ive got it but not in good condition. its not straight and wont provide a good seal against the window.
Manual conversion sold.
Drivers headlight and passenger rear light sold.
Boot lid and rear bar sold.
Still got plenty here.
Also have R32 RB20 ABS Tailshaft available $100
Hybrid (i think) front mount cooler $60
Interested in the:
Stock Seats
Clear indicator
Glove box (I hope this is the same as 4-doors)
Stereo surround
AC/Climate control
DIN brackets if you happen to have them
pick up SE burbs.
Interested in the:
Stock Seats
Clear indicator
Stereo surround
AC/Climate control
pick up SE burbs.
PM sent
    • Welcome Thomas! Sounds like you've made some progress. Are you able to drive it and enjoy it a bit now ?
    • HUMVEE are fine in big open areas, but they are problematic on the street and tight areas As for reliability, some of the  US Army guys I have chatted with have said that when they were working they were fine, but, the do spend alot of time in workshops for multiple reasons, admittedly, they did get a hard time by the boys and girls who drove them I would definitely put them in the "buyer beware" category  They do look tough as nails though
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
