Wrecking R32 GTS-T.
Main items listed below, however too many parts to list them all. If you need something, just ask as there is every chance i'll have it.
Also have a few other random parts from RB25 and RB26. See bottom of post.
Pickup from either Traralgon or Melbourne - Sth eastern suburbs.
Happy to post if buyer pays postage.
Can supply more info and better photos for anything on request.
PM, or call / SMS - Mike 0412 678 973
Front guards - Both LHS & RHS. Black. No dents or creases. $50 each
Rear bar (not inc reverse lights) $60
Boot lid $50
Headlights $80 each, or $150 pair
Rear lights $40 each, or $70 pair
Indicators - 1 x LHS clear, 1 x LHS orange, 1 x RHS smoke $50 each
Complete dash - has the bubble in the usual place. See pics. $100
Glove box/s $30
Center console/s $30
Speedo/gauge cluster 139xxx km's $80
Speedo surround (inc headlight switches etc) - one in standard black, one painted silver - see photos. $60 each
Kick panels LHS & RHS available $20 each
Steering wheel surround plastics $30
AC/Climate control unit $40
Plastic stereo surround - painted silver - cracked at bottom $20
Gearbox/manual conversion kit - everything except flywheel $750
Top mix racing seat - no rails. Set up in fixed position in R32. $80
Standard seats - driver and passenger - good condition $35 each
Standard radiator $80
Standard fan $20
R33 RB25 tailshaft $100
Standard RB26 turbos - excellent condition $250
RB26 airbox $60
More available that i have forgotten about. Just ask if you need anything in particular.
Prices on most things are negotiable. Happy to consider reasonable offers.
Mike - 0412 678 973
post-33046-0-78731800-1409816106_thumb.jpg post-33046-0-57055900-1409816198_thumb.jpg post-33046-0-99932000-1409818789_thumb.jpg
post-33046-0-22025200-1409818889_thumb.jpg post-33046-0-31316100-1409819347_thumb.jpg post-33046-0-60879800-1409819784_thumb.jpg
post-33046-0-23047500-1409819995_thumb.jpg post-33046-0-25775100-1409820120_thumb.jpg post-33046-0-77783400-1409820522_thumb.jpg
post-33046-0-08354700-1409820666_thumb.jpg post-33046-0-81143200-1409820773_thumb.jpg
Edited by xtra.5
Mate, I'm looking for the driver side rubber strip that goes between door card and the glass on the inside. If in good condition
Got it?
Got it?
Got it?
Do you mean the felt bit that is attached to the top of the door trim?
any updates mate? have you got this trim part?
Hey mate, ive got it but not in good condition. its not straight and wont provide a good seal against the window.
Manual conversion sold.
Drivers headlight and passenger rear light sold.
Boot lid and rear bar sold.
Still got plenty here.
Also have R32 RB20 ABS Tailshaft available $100
Hybrid (i think) front mount cooler $60
Interested in the:
Stock Seats
Clear indicator
Glove box (I hope this is the same as 4-doors)
Stereo surround
AC/Climate control
DIN brackets if you happen to have them
pick up SE burbs.
Interested in the:
Stock Seats
Clear indicator
Stereo surround
AC/Climate control
pick up SE burbs.
PM sent
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
