Do you have all the boot carpet pieces?
I need the left and right sides so that when I install a tower bar I can cut the extra set and not mine :P
Edited by Matvei27
PM sent
  • 4 weeks later...
Did you have pods?
I have some, but they are blue and on one side it has been hit and inverted the bottom of it. Can send pics if you want. Just PM me your number
Indicator stalk?
Sorry mate, indicator stalk is gone.
I'm keen on the brace that runs behind the glovebox. It's a metal brace that the glovebox actually bolts too. I took mine out and have misplaced it.
Hi mate, do you have the exhaust for sale? If so, what are specs? Cheers
Sorry bud, im keeping the exhaust for my build.
PM sent
hey chasing hose/connector that hooks onto aircon in engine bay and hose/connecor that leads to power steer pump.
Hey mate,
there was no aircon in the car im wrecking, and the power steering pump and lines have already been sold.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
