Changed turbo water feed line as hose was weeping from intake to y pipe to turbo on rb20det in r32 topped up coolant again and now heater isnt working.... bleed it 3 times and at best its slighty warmish then goes cold again..... wtf.... help
Can't help you.
Changing the line doesn't do anything to the heater. So either your heater is blocked now for some reason or you aren't bleeding it right or you did something else.
Edited by Ben C34
Ok so i found that when i set it to FH it blows hot air.... theres a metel sensor or something in top heater hose has elec plug and metel t peice with rubber block off on it ...can this be causing it as pulled the hoses/sensor out way to get to turbo water feed ???
As far as I know, these cars run coolant through the heater core constantly, cabin heat being regulated by the air mix door.
That sensor in the hose at the firewall tells the aircon amplifier unit the actual coolant temp.
If you've disconnected it you'd see a fault code 23.
