Building this thing from a rolling shell into a dedicated drag car build.
- 3.4L Spool stroker kit with drag I-beams
- TH400 3-speed auto
- Mickey Thompson ET Pro Radial tyres (275/60/15)
- Goal is 7.xx seconds @ 175-ish.
https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/
Holy Shit, that car reminds me of buster!
Funny that! :)
Bought valves, springs, locks, retainers, guides and seals today. Got a great deal from Fabre on the lot and it was all in stock.
Head being disassembled tomorrow and the block arrives tomorrow to begin prep too.
Edited by 2rismo
Very cool.
Do you have an approx completion date?
ASAP. I've dragged my feet with other pursuits in the time I've had it. It's all systems go now. I'd like to race at Sydney Jambo in March with testing prior.
Precision Gen-2 8891 and 66mm gate:
Enough assembly lube for 8 RBs:
Dirty, dirty diesel:
This is unnaturally attractive:
Almost all of this is staying out. Anyone need any airbag stuff?
All caged up:
Lots left to do:
  • Like 1
I'm curious to see the machine work required to fit the RB head.
Any reason you are going the TH400 over a lighter option?
Will be sweet to see this car ripping huge skids again
I'll have photos of the entire process of adapting the head to the diesel block. Will also be machining up and fitting plugs for the head so there is no water near the deck at all. The block will also be filled to the deck.
TH400 was chosen because the power I expect this to make will be more than what my prefered trans will take (C4). The aftermarket support for TH400 is now so strong that they can be made unbreakable at this power level and application. They're just such a known quantity.
The street car ran 10s pretty easy and needed a cage, GTR rear end, different suspension etc. It has since had 30psi jammed into it and it made 415kW. It will run 9s soon.
This car was offered to me as a roller with everything already done. As hard as it was to sell the red car, I have a history with this car too so it was an easy decision.
Kyle from 6Boost is making the exhaust manifold for this engine. Will fit a 5in dump without cutting up the bay and include the 6 x EGT bosses. Stoked.
Going for his 'pro-mod' manifold?
This should be amazing!
Out of curiosity what sort of rpm are you thinking of turning it to? I'm keen to know what sort of piston speeds people think are possible, especially with a 94mm stroke.
We currently turn ours to 8000rpm in our circuit car and that works out about 25m/s which is getting up there. Your engine being for drag purposes I suspect you are intending to turn it a little harder??
Edited by r33_racer
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
