Building this thing from a rolling shell into a dedicated drag car build.
- 3.4L Spool stroker kit with drag I-beams
- TH400 3-speed auto
- Mickey Thompson ET Pro Radial tyres (275/60/15)
- Goal is 7.xx seconds @ 175-ish.
https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/
Holy Shit, that car reminds me of buster!
Funny that! :)
Bought valves, springs, locks, retainers, guides and seals today. Got a great deal from Fabre on the lot and it was all in stock.
Head being disassembled tomorrow and the block arrives tomorrow to begin prep too.
Edited by 2rismo
Very cool.
Do you have an approx completion date?
ASAP. I've dragged my feet with other pursuits in the time I've had it. It's all systems go now. I'd like to race at Sydney Jambo in March with testing prior.
Precision Gen-2 8891 and 66mm gate:
Enough assembly lube for 8 RBs:
Dirty, dirty diesel:
This is unnaturally attractive:
Almost all of this is staying out. Anyone need any airbag stuff?
All caged up:
Lots left to do:
  • Like 1
I'm curious to see the machine work required to fit the RB head.
Any reason you are going the TH400 over a lighter option?
Will be sweet to see this car ripping huge skids again
I'll have photos of the entire process of adapting the head to the diesel block. Will also be machining up and fitting plugs for the head so there is no water near the deck at all. The block will also be filled to the deck.
TH400 was chosen because the power I expect this to make will be more than what my prefered trans will take (C4). The aftermarket support for TH400 is now so strong that they can be made unbreakable at this power level and application. They're just such a known quantity.
The street car ran 10s pretty easy and needed a cage, GTR rear end, different suspension etc. It has since had 30psi jammed into it and it made 415kW. It will run 9s soon.
This car was offered to me as a roller with everything already done. As hard as it was to sell the red car, I have a history with this car too so it was an easy decision.
Kyle from 6Boost is making the exhaust manifold for this engine. Will fit a 5in dump without cutting up the bay and include the 6 x EGT bosses. Stoked.
Going for his 'pro-mod' manifold?
This should be amazing!
Out of curiosity what sort of rpm are you thinking of turning it to? I'm keen to know what sort of piston speeds people think are possible, especially with a 94mm stroke.
We currently turn ours to 8000rpm in our circuit car and that works out about 25m/s which is getting up there. Your engine being for drag purposes I suspect you are intending to turn it a little harder??
Edited by r33_racer
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
