  • 4 weeks later...
Head back from CNC. They roughed most of the hard stuff out. Now getting measured, hand-finished, all the usual stuff. Valves, seats and whatnot are all there too now and the cams should have arrived in the shop today. Tyres arrived at my place too.
  • Like 1
Cleaned out some of the engine bay today. Took hours. Barely scratched the surface and then one of the bloody wiper arm bolts has corroded itself in. Bugger. Still sooo much crap to remove.
Before:
After:
It's not a proper build thread until there's a foot in a photo :)
Those ports look huge, can't wait to see some results.
They're a tiny bit bigger now and the exhaust is matched to the manifold. Plenty of meat in the 6boost runner/flange to make it perfect. I pick up the new Plazmaman billet runner intake next week. Will be interested to see how much, if any, work that needs.
  • Like 1
I've done the street car thing, now I'm doing the race car thing. No water in the block (or between the head and the block, but that comes later), methanol, comp', big boost, 7s.
Buh-five-tah is a legendary car. :D
Edited by 2rismo
  • Like 1
  • 4 weeks later...
Progress on engine assembly. Got the block back from Jack Bros after a line bore and hone and being tapped for 12mm head studs as well as being fitted for the steel caps.
Osama bin Grindin'.
Needs a couple of thou off everywhere and a few off the thrust. Was too tight everywhere but very consistent (maximum .001 either way of the middle.)
Turbosmart FPR-3000 showed up too. Will be running Siemens 2400s x 12 by the looks of things. There goes $2k.
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
