  • 4 weeks later...
Head back from CNC. They roughed most of the hard stuff out. Now getting measured, hand-finished, all the usual stuff. Valves, seats and whatnot are all there too now and the cams should have arrived in the shop today. Tyres arrived at my place too.
  • Like 1
Cleaned out some of the engine bay today. Took hours. Barely scratched the surface and then one of the bloody wiper arm bolts has corroded itself in. Bugger. Still sooo much crap to remove.
Before:
After:
It's not a proper build thread until there's a foot in a photo :)
Those ports look huge, can't wait to see some results.
They're a tiny bit bigger now and the exhaust is matched to the manifold. Plenty of meat in the 6boost runner/flange to make it perfect. I pick up the new Plazmaman billet runner intake next week. Will be interested to see how much, if any, work that needs.
  • Like 1
I've done the street car thing, now I'm doing the race car thing. No water in the block (or between the head and the block, but that comes later), methanol, comp', big boost, 7s.
Buh-five-tah is a legendary car. :D
Edited by 2rismo
  • Like 1
  • 4 weeks later...
Progress on engine assembly. Got the block back from Jack Bros after a line bore and hone and being tapped for 12mm head studs as well as being fitted for the steel caps.
Osama bin Grindin'.
Needs a couple of thou off everywhere and a few off the thrust. Was too tight everywhere but very consistent (maximum .001 either way of the middle.)
Turbosmart FPR-3000 showed up too. Will be running Siemens 2400s x 12 by the looks of things. There goes $2k.
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
