275 Radial R33 Drag Build
2rismo
What's the plans for squeeze? Full WON REVO set up?
Fantastic build so far... damn those gudgeon pins are thick!
Much buggering about bolting an rb head and crank to the rd28 block?
Cheers
J.
Cheers
J.
No gas yet.
No real hassle on the block.
Picked all this gear up today.
  • Like 2
I'm pretty keen to see what the ass end looks like once you have shaken it down and get it to a point where it will hook up well.
Cheers
J.
Leaf springs and track bars!
Cheers
J.
Will be interesting. The RIPS GTR sixties hard on standard gear but has slicks to take up some of the load at the hit.
The support Haltech give their customers is outstanding and they're genuinely interested about developing the product to better suit my application. From the top down they're a great bunch.
They still help me out with my clunky old E11
Spent a few hours stripping stuff out of the car last night. Every time I remove a panel or undo a bolt there's another mile of wiring or another module, controller or motor to be removed. No wonder these things are heavy.
Also started trying to work out how the tyres are going to fit. Right now, they're not going to but we can fix that.
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
