Hey guys. I've got an RB26 in pieces in the garage. I'm doing a standard rebuild reusing the pistons/rods but replacing main and big end bearings. New MLS head gasket, ARP head studs. New genuine piston rings too.
I'm about to Hone the block and clean up the deck ready for the new gasket. The Head is getting re-conditioned and the machine shop is going to take up to 1mm out of the head for me.
My question is about honing the bores. Which type of hone tools is better?
A brush type like this: 909.jpg
or the stone plate style: HoningStone.JPG
Either way I will be borrowing the tool.
Also, I've been told not to use a razorblade to clean up where the old gasket was on the deck. Incase of scratching. Is this really an issue on a cast iron block like the RB26? Someone told me to use some oil or other lubricant along with the blade to protect the surface. Someone else told me to use a stone of some description. What is the consensus here?
For those who have shaved some thickness out of the head in order to bump compression could you share your experiences? How did it change the way it drives? Is it noticeable? My other concern is how will I go getting cam timing spot on. I'm thinking some adj. gears might be on the shopping list anyway seeing as I'm keeping factory cams.
Any input would be appreciated. Thanks fellas
I'd suggest if you are using an MLS head gasket, that you take it to a machine shop and get them to surface the block properly.
It won't seem so great having done it at home when it leaks, those gaskets need a pretty damn good mating surface
Home honing is not good. Especially with the ball style tool as it just conforms to the bore rather than trueing it up.
Definitely worth paying for a hone, and as 89CAL said, if using an MLS gasket you really should have the deck faced to suit.
yeah well the original cross hatch is very visible. there's barely a glaze at all. I'm very reluctant to take the block away, tempted to assemble it as is. how bad can the surface be? It's a low KM engine that had the typical R32 oil pump failure.
before anyone flames me for this. I had a sport accident 4 weeks ago and fractured 3 vertebrae in my neck along with soft tissue damage. 3-4 months off work isn't cheap. Whereabouts in sydney would I be able to get it done without being ripped off?
can anyone share their experiences with a slight bump in compression for a standard internal RB26?
Edited by Blackkers
The material removed from the head would make no noticeable difference to how it feels or drive's,
It may possibly feel a bit more crispy than before due to being a tighter engine after rings etc.
As for honing, it will need some form of hone before fitting new rings as they need somthing to bed into. If you just assemble it as is, it will just burn oil and have heaps of blowby eventually.
And if you do it at home, the block WILL need a PROPER wash after, degrease, scrub, scrub some more, pressure wash, scrub all the little nooks (requires special cleaning brushes, like gun cleaning tool's) degrease again, oiling etc. Its not just a case of hone and wipe!
If you get a shop to do it, they can put the h6 finish (or what ever its called, cant remember) on the block to seal the gasket, power hone it to give the 100% correct cross hatch angle, and bath the block, it will look 100% brand new! And work also!
+1 to what others have said. There's no easy or cheap way to build a motor correctly to last.
It is unclear what other components and what thickness of MLS you are using. That will affect your overall compression ratio.
I ordered 9.0:1 pistons but the block and head I bought off another member were both shaved ~1mm. Combined with a 1.3mm head gasket yeilded 11.3:1! I had to shave 2mm off the top of the pistons to bring it back to 9.0:1. Be sure that your compression ratios are going to be in check if you have a modified set up.
So the block is already bored and honed? You say you already have the cross-hatch pattern. Again, I asked my shop to use a torque plate, check tolerances, true bores and hone. They had to do an additional 0.0004 to bring the bore back into round.
I was never going to assemble without a hone But I am tempted to give the block to a shop to do the hone and surface the deck then clean the block
I don't know which size headgasket I can use yet. Once the pistons are in I can measure the deck height and calculate the squish which will let me pick a head gasket.
OR seeing as I'm using all the factory rotating assembly with the stock deck height does anyone know the factory deck height? that would at least get me close enough to buy a gasket now
The cross hatch is still there from the factory. Which doesn't guarantee that it's a low KM block but it at least tells me it wasn't a super high KM block. Car has 90,000 on the dash
Edited by Blackkers
I've done in chassis rebuilds at work where there simply wasn't a budget to remove the block, crank etc.
We use the brush type hone on a drill with plenty of CRC for lube. Obviously the bores have to be thoroughly cleaned. ATF is very useful here. An oil stone, along with CRC, is used to clean up the block surface. Alternatively, if the surface is quite rough to start out, you can use a steel block or similar with varying grits of sandpaper and an oil stone to finish.
It should be noted though, that these were standard rebuilds in daily drivers, i.e. A Transit van, and not on a highly strun RB26. And it was more of a case of get it in, get it done and get it going.
If you use a super thin gasket your mating surfaces may not be good enough. If you use a factory stock gasket you should still end up with a little higher compression. FWIW I have used stone type hone and a sharpened piece of a large machine hacksaw blade for a scraper.
Okay the block is with the machine shop now. The owner is really looking after me, he's going to machine the deck and hone the bores for free.
Also I got the crank back with the bearings they ordered. Also the crank collar is on.
The rings I got are standard factory rings so I imagine I won't have any issues with sizing but I'm going to check the gaps anyway once I get the block back. Then I can assemble the bottom end, measure the deck height and order a head gasket.
Can't wait to get it together
  On 17/09/2014 at 6:14 AM, djr81 said:
Why the ARP studs? Would you not be better off with the standard studs if it is a standard rebuild?
Is there a draw back to arp studs?
How much do standard bolts cost?
I plan to run 1.5+bar of boost through it on relatively small turbos with higher than factory CR. I can't see a reason not to other than the cost.
  On 17/09/2014 at 6:19 AM, Ben C34 said:
Blackkers, be honest, what did you do to get the work for free ;)
haha well free is a relative term.. He asked me to tell my friends about his shop. So if anyone needs some work done, speak to Gary at Leon's engineering Artarmon he's an absolute legend.
They chemical cleaned all the bits and pieces for free too
  On 17/09/2014 at 11:11 AM, omnigear said:
good read, would love to do a build one day..
good on you for having a go Blackers
  • Like 1
    • Stock RB fuel pressure is near enough 43.5 psi, so the latency in that table at 31.6 will be close. You can see that 7 or 8 psi equates to about 0.4µs extra latency. So if you wanted to interpolate between the 31.6 and 39.9 psi values you could say you're going up about 2 psi out of those 8, so add about 0.1µs, which is barely worth talking about and is quite possibly wrong because ideally you would fix the latency while running at the appropriate conditions on the dyno, with a wideband sniffing its butt.
    • The pressure, is what you set the fuel pressure to. If you have the factory fuel reg, you'll need to find the factory spec. I don't know it off the top of my head, but someone else might.
    • For others, what GTSBoy states here should be paid attention. Why? Well lots of people play with different engines, and they LOVE to change things like remove AC, or steering pumps etc, and it lends to them needing to move the tensioner too. You want your tensioner, particularly those that are sprung or hydraulically tensioned, to be the first thing after the harmonic balancer, or technically the "last" pulley in the chain. By saying last pulley, I mean look at the direction the crank spins when the engine is running, follow the belt from where the crank is pulling the belt FROM, and keep following that until you're between the last pulley/accessory on the belt and about to reach the crank again, this is the spot where you put the tensioner. This is the area that will always end up with slack. This is worked out exactly the same way for chains too, as the physics is the same for them. The crank pulley is where all the force to drag the belt around comes from. You will never ever get rid of the slack that appears, especially under load. The tensioners job is to keep the belt loose enough when stationary that there shouldn't be out of sync movement in slow movement, and then be tight enough when running, that the belt can't jump off any gear and get damaged. Too tight, bad things happen, too loose, bad things happen. Have a tensioner (mainly sprung/hydraulic one) in the wrong spot, it can't actually do anything about keeping the tension.
    • It was gonna take much longer for the 440cc so I'd thought I'd risk it with the 550cc. They finally arrived and I couldn't wait any longer (I could but I was quite excited after 2 months) and installed them myself. Removed the old injectors, inserted the new and connected everything up. Before starting the car, I tuned the injector size from the factory 270cc to 550cc using Nistune.   This did some of the calculations automatically which catered for the TIM. The latency however did not seem to change. Deatschwerks have the tuning data available for each injector online, and I had a look at it. It has a table which relates to latency according to pressure and voltage (see below image). Nistune requires the 14v value, but I am unsure of which pressure value to look at (my lack of knowledge and experience have something to do with this). The highlighted value is close to my current latency which is 760µs. It is for 14v which makes sense, and the pressure is 31.6 Psi.   I still gave the car a test drive to see how it goes, and honestly it has never felt so powerful before (and some people say the RB20DE is very weak?). I really enjoyed the drive. Side note; The injectors are quite noisy, which someone mentioned before. This does not really bother me however. I will still ask my mechanic to have a look at it and perhaps ask a tuner to fine tune it if they have the knowledge.
    • Also true. But imagine not wanting new injectors? Imagine wanting to use 30 year old injectors?
