  • 4 weeks later...
Got a new front bumper for the car as my current one has had a tough life
I got the bumper and all brand new hardware for mounting the bar, and the front lip to the bar, Thankfully the mesh, reo, vents etc etc can be reused from my old bumper, will be saving that aside for when the car goes in for paint (hopefully soon!)
Thanks to the guys at justjap for being really helpful and organizing the fastener kit!.. I should note, they told me that the bar has now been discontinued from nissan and i was one of the last people to get a new one that they know of, which is exciting! - I guess you can still buy the stock GTR bar, but the N1 version is now no longer Available! if you guys are looking for one, hit up a retailer soon and get one before they're gone :)
Cheers
I don't think it's an actual kit by nissan, but the boys at just jap put it together for me
Parts are as follows
Front bumper attaching to the front reo bar
01461-00781 - SCREW x10
01241-00791 - CLIP x10
Front lower lip to front bumper
K9601-13921 - BOLT x5
08911-2062H - NUT-HEX x5
N1 Front bumper cover (try your luck, some nissan dealership might have one sitting around?)
62022-06U25
Some screws and clips from the 10 are used to secure the lip also
There is also a bag of 7 push lock clip things which don't have a part number on the bag, sorry
hey mate any idea on your wheel alignment settings?? on the rear?
Hey man, to be honest i don't, yet..
I can tell you from my eyes it's cambering in at the back a considerable amount from being lowered as much as it is and also toe'ing in due to the arms being at such odd angles, planning on raising it soon to hopefully fix that, but the guards will need some attention i think
Car has been good lately, took it for a drive up to the blue mountains yesterday
Met up with a very well known forum member
"that car from speedhunters" haha
Explorered a few of the roads around there, some very nice sweepers and tight hairpins, highway patrol also had a good look at both of our skylines on the side of the road
Weather was okay, overcast and patchy rain, thankfully it wasn't too hot and the roads were quiet!
Took the road all the way up through Bilpin and had a chunky steak pie for lunch, followed by some local made fudge for the road, next time ill get the apple pie, looked really good
Drove all the way up to the Evans lookout. I would have loved to have kept going all day, there's certainly a lot to explore but i was getting really tired as i didn't get the best nights sleep and had a drive back to Sydney ahead of me
Then all the way back home!
Thanks Terry for suggesting a few roads and coming to say gday, nice to meet you :)
Not much has been happening on the modification front
I raised the car about 30mm all round, i think it looks a lot better, it's much more comfortable and i can get into my suburb without any bumps of scrapes now which is great
But I'm about to leave to go the the UK for 6 weeks so I'm putting the car in the garage at my dads house and leaving it there until i return :)
Edited by Jordy32
  • Like 2
  • 2 months later...
This car has unfortunately been sold.
I am focusing on my new job for the time being and hope to be playing with cars in a few months when I have had a think about what I want, and decided on a direction to go.
I will still be on the forum most days chatting to people and offering advice, If a mod could lock this thread? or we can let it simply fade away.
Thanks everyone
:cheers:
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
