As title says, what is the absolute most responsive aftermarket turbo available for an RB25?
The factory turbo on R33's delivers great response and driveability and can deliver around 10psi of boost safely without spinning the ceramic turbine wheel off.
If not for the ceramic turbine wheel, would I be correct in assuming that the factory turbo would be able to deliver roughly 14psi without losing efficiency, and make around 230rwkw?
Is there a turbo with similar A/R's, trims etc to the factory Garrett but with steel/inconel/alloy wheels?
If so name it please!
We can high flow your standard turbo that has similar response to factory, while making a lot more power.
That is 20psi by 3400RPM maxing 320rwkws on E85. We usually seeing around the 260rwkws on P98 fuel.
Every thing looks stock standard, and bolt back on the way it was. No fabrications required.
I just sold my #hypergear highflow because it was too uneconomical for me to run. The power was great, but I don't need or want "20psi by 3400rpm". I can't afford the fuel costs or supporting mods to run 320rwkws.
I literally want the little factory Garrett but with a metal turbine wheel, so I can run a measly 12-14psi and make a little over 220rwkws on PULP with a PowerFC. I want full boost at ~2500rpm like the stock turbo!
I've got one on an RB25det as a street car. With boost leaks it will make 20psi by about 3300RPM uphill in 4th.
you never have to change down gear above 50km/h in 4th.
but it doesn't respond as well as the stock turbo. The factory turbo makes the car feel like a small block chevy compared to the highflow. But it has major drawbacks.
If rebuilt to standard specs with a better bearing cartridge and steel wheels I'm sure you won't lose much response and on e85 you could push probably up towards 16-18psi. Remember ceramic/nylon wheels are lighter (I assume) which helps transient response
  • Like 1
The factory turbo makes the car feel like a small block chevy compared to the highflow...
Yes!! And that's what I want!
I've had a 270rwkw Skyline, and as fun as it was, it was more fun around town (where I drive most) with the stock turbo. Next to no lag, and enough power to have fun.
Edited by colourclassic
Just send it to Hypergear and ask for it to be rebuilt to standard Nissan specs but with steel wheels and not high flowed.
Can hypergear do this?
Stock turbocharger was making 10psi by 2800RPM. Any thing that build boost faster results in compressor surges on partial load.
Most of the high flows I've done were built to generate about 260rwkws on P98 fuel. I can build some thing smaller to match factory boost curve, that works with standard ECU also.
By the way, The original turbocharger that I've high flowed for you was a Neo turbo. R33 turbine housings are smaller, in comparison is 500RPM more responsive.
A good used HKS 2535 may be what you need.
Crazy response, but will choke at top end. 230rwkw type of power.
I think they can handle high teens worth of boost.
or for a little bigger look at the HKS GT-RS
This^^
If you can build something which will match the factory boost curve/response, please PM the info Stao! I'd prefer a roller bearing CHRA too if possible!
You know the bigger the turbo the more economical the car is? :)
You're not always on boost haha.
In saying that, if you're after response check out Borg Warner turbos. They're truly amazing however will burn a hole through your pocket
Sounds like you're after my setup...
MX Performance exhaust manifold (with 1" runners), External wastegate with HKS GT-RS turbo with internal wastegate removed and welded closed.
With this setup the turbo is just as responsive as stock ~ 5 psi at 2000 rpm, however it has around 280 rwkw. Economy wise, I average around 10litres/100km.
My car is a daily drive, so I wanted no compromises on driveability... Check out my build thread for more info...
http://www.sau.com.au/forums/topic/409509-rynos-r32-over-a-decade-and-counting/
  • Like 1
There's also some companies offering bolt ons (exhaust side at least) for the GTX2860/63/67. Probably better off getting Hypergear to refurb a stock turbo, but throwing it out there for interest.
SonicPerformance is doing turbo with housing:
http://www.sonicperformance.com.au/Turbocharger-Upgrades/Nissan/Skyline-_dash_-Single-Turbo/pl.php
Kudos has a kit on GTX2867 only:
http://www.kudosmotorsports.com/catalog/garrett-turbocharger-kit-garrett-gtx2867r-nissan-skyline-r33-gts25t-r34-25gtt-rb25det-special-introductory-price-p-1459.html
Currently running a td05-18g, previously a hypergear hiflow, on r33/rb25. Both good for comparable to stock response, for the OP i would prob go with Stao's offer to build u one for your needs. I like the td05 but not really worth the dicking around to get to fit.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
