Gating32 Posted September 9, 2014 Share Posted September 9, 2014 I recently put a 25det into my 32. It was all running fine until i did a little boost. After that the car started idling really high. When you are sitting there the car starts idling at 5k and when you are driving it starts to pull by itself. Could anyone help me with the reason why its doing this?? Cheers Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/ Share on other sites More sharing options...
Ben C34 Posted September 9, 2014 Share Posted September 9, 2014 Throttle stuck? Vac leak if map based ecu? 1 Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7385787 Share on other sites More sharing options...
GTSBoy Posted September 9, 2014 Share Posted September 9, 2014 popped hose clamp Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7385910 Share on other sites More sharing options...
Gating32 Posted September 12, 2014 Author Share Posted September 12, 2014 I have checked for vaccum leaks and air leaks and nothing. Im thinking its the tps becuase it only idles at 5k after you have fully accelerated Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7388227 Share on other sites More sharing options...
Ben C34 Posted September 12, 2014 Share Posted September 12, 2014 No way can the tps cause it to idle that high. Not possible. Have you checked the throttle returns fully all the time? Is your cable all frayed? Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7388229 Share on other sites More sharing options...
Jordy32 Posted September 14, 2014 Share Posted September 14, 2014 The engine has to get quite a bit of air to keep revs at 5k which is why i wouldn't think it could be a sensor. there sounds like something is wrong with the throttle body causing it to stay open or a big vac leak; any bolts missing on the plenum or anything? Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7389053 Share on other sites More sharing options...
Cxxo Posted September 14, 2014 Share Posted September 14, 2014 My mate has a R32 with the 20det had the same issue but was "idling" at like 7k... it was his throttle cable getting stuck and the nuts where loose on the cable near the throttle body.I'd check there first. Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7389207 Share on other sites More sharing options...
Ben C34 Posted September 14, 2014 Share Posted September 14, 2014 So. Check the throttle. As has been mentioned 5 times now. Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7389213 Share on other sites More sharing options...
Gating32 Posted September 15, 2014 Author Share Posted September 15, 2014 Cheers for everything it was cause there were two bolts missing on the plenum so far shes running good Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7389783 Share on other sites More sharing options...
Ben C34 Posted September 15, 2014 Share Posted September 15, 2014 Wow! Crazy it could rev that high due to the leak. Glad it's sorted. Was it a map based ecu? Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7389797 Share on other sites More sharing options...
Gating32 Posted September 15, 2014 Author Share Posted September 15, 2014 Haha well she hasnt reved out to far yet. and its all on a standard ecu Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7389819 Share on other sites More sharing options...
Jordy32 Posted September 15, 2014 Share Posted September 15, 2014 Good to hear you got it all sorted Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7390033 Share on other sites More sharing options...
Blackkers Posted September 15, 2014 Share Posted September 15, 2014 crazy. I had a massive leak in the plenum due to a buggered gasket and it only caused a lean and hunting idle. on boost AFRs were below 10 and it felt pretty powerless. also wouldn't reach normal boost levels Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7390171 Share on other sites More sharing options...
SargeRX8 Posted September 16, 2014 Share Posted September 16, 2014 I too had a huge leak. Got rough lumpy idle not a 5k idle Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7390625 Share on other sites More sharing options...
Gating32 Posted September 25, 2014 Author Share Posted September 25, 2014 Unfortunately the problem has started again Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7396522 Share on other sites More sharing options...
Ben C34 Posted September 25, 2014 Share Posted September 25, 2014 Probably cos your throttle is getting stuck. Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7396530 Share on other sites More sharing options...
sleptema Posted September 25, 2014 Share Posted September 25, 2014 Probably cos your throttle is getting stuck. Maybe his throttle is getting stuck? Dunno why it hasn't been mentioned before. Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7396536 Share on other sites More sharing options...
Gating32 Posted September 25, 2014 Author Share Posted September 25, 2014 I've taken the throttle off and it closes fine, i checked the accelerator cable to make sure that's fine which it is. so might just take the intake off and change the gasket Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7396587 Share on other sites More sharing options...
Ben C34 Posted September 25, 2014 Share Posted September 25, 2014 Or you could pressure test to find a leak. Link to comment https://www.sau.com.au/forums/topic/448452-rb25det-idle-problem-help-5k/#findComment-7396599 Share on other sites More sharing options...
