R32 Gtr nismo cluster $400
Hks glove box gauge holders $180
Trust drag Intercooler 100mm $700
R32 Gtr Coilovers hks drag fronts with swift springs, apexi rears with swift springs. Great condition $600
Hks triple plate clutch 90% left $1000
Apexi power Fc pro better than original power Fc suit Gtr $750
Apexi power Fc and hand controller suit Gtr $650
Apexi power Fc and hand controller suit r34 gtt neo $800
Recaro drivers seat on recaro rail suit track car $300
Recaro seats drivers and passenger on recaro rails suit skylines mint condition $1000
Garrett gt3582r turbo kit for rb25 comes with stainless manifold etc $1900
Nistune Ecu suit rb25 $400
Turbosmart Eboost 2 $400
Hks hard piping kit suit r32 Gtr $350
Trust type r bov $300
R33 gtst tein fully adjustable drift master Coilovers $700
R33 gtst Coilovers tein fronts unknown rears $450
Os giken twin plate clutch push type $700
Greddy boost gauge $70
Greddy exhaust temp gauge $70
Garrett 2860r-5 turbos with modified smaller housings for response $1100
Splitfire coilpacks rb20 rb25 rb26 $330
Blitz dual stage boost controller $180
Intercooler kit suit high mount turbo and front facing plenum comes with bov $200
Oil cooler and relocator kit $180
Brand new top speed dump pipes suit Gtr $200
Momo dished steering wheel genuine $130
Custom oil catch can removed from a 32 sits next to battery $200
R33 alloy radiator $90
Rb26 billet fuel rail $90
Bosch 040 fuel pump genuine $100
R32 Gtr tein rear Coilovers $180
Sabelt 5 point racing harness great condition $100
Walbro fuel pump in 32 gtst cradle $90
R32 Gtr custom exhaust 3.75-3.5inch with massive tuned length front pipes best sounding Gtr I've heard yet $350
Whiteline rear sway bay from a 33 gtst $100
Cusco rear camber arms for r32 Gtr gtst $130
Jdm hicas lock bar suit r32 came on a car from japan $50
Hks intake kit for Gtr elbows and filters $150
Z32 afm with plug $150 like new
Brand new omp steering wheel copy $50
Hks oil cap genuine $70
Greddy oil cap genuine $60
Nismo leather gear knob $70
R34 couple turbo back 3 inch exhaust $180
Gold Coast
0487924497 please text for pics
Hi mate, how many litres is the catch can and does it have all the fittings.
Ill take it if its 3 litres and atmosphere vented
Edited by Strick.
  • 3 weeks later...
Willing to ship to the US for these and cut me a deal on buying both combined?
^--- actually, I only need this. Willing to ship to the United States? You have a PM. Tried to txt your number but it wouldn't send.
I take it this guy isn't logging in to check this thread or PM? Can someone please text this guy and ask him to log in 'cause being out of the country I can't text him.
Ah, thanks for that info. If the seller isn't interested in communicating, I'm just gonna look elsewhere.
I've sent this guy 3 texts on separate occasions and numerous pm's about buying stuff. Sent him one about buying 3k worth of shit and no reply.
  • Like 1
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
