What Michael said.
There are some cool advantages to having a cage though,,,especially a full one.
1/ You will feel so much safer whilst thashing the crap out of her.
2/ You will now have proper anchoring points for a full harness and again you will feel safer whilst thrashing the f**king crap out of her.
3/ If you jack her up in the right spot you can change 3 wheels at once.
Cheers
Neil.
  • Like 2
well it might be a bit late, but to answer your question, possibly yes.
In many sup regs cars which are not registered need a log book. And a log book needs a CAMS certified cage.
Instead of generic interweb advice, I'd check with the clubs you intend to run with.
  • Like 1
I'm only new to the track scene and the only tracks days I'll be running in is anything I see on here and the sau championships.
I'm Not sure what clubs there are I could go through. So any info would be very helpful.
Edited by BLK-51N
Can anyone expand on the Vic drifting requirement for a cage? Is that only for the guys in the actual competition, not the guys just out there having fun. Or do they not run them on the same day, and there are different events for amateurs that just want to have some track time
  • 1 month later...
Ended up going a full cage 6 point with a few extras so I can enter wtac open class next year from mcqueen motorsport. Set me back around $2500 including mounting seats.
  • Like 1
Bit late but you need CAMS specification half cage as a minimum for any Vicdrift event at all, you won't be allowed on the track without one, no matter what the event is or what class you are in.
  • 3 weeks later...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
