I'm considering parting with my s13 Silvia-
I've owned the car since 2004, it's been registered the entire time, it has also gone from a near standard daily driven road car, to a very well sorted club car- suitable for just about any form of Motorsport.
2012-13 I used the car in the SAUVIC
Club Motorsport championship, coming 3rd in modified rwd class, I don't have lap times for tracks handy but could dig them up-
The car is very reliable and aside from a blown exhaust manifold gasket it needed no attention throughout the club Motorsport days, aside from consumables- (tyres/oil change / brake pads)
The car has been hidden away in a garage under a cover for the best part of two years with only the occasional trip along the great ocean road, so I'm considering moving on.
S14a sr20det low km engine installed in 2003.
Apexi head gasket
Tomei rocker arm stoppers
Tomei poncams
Sard 550cc injectors
Bosch 044 fuel pump
HKS 2540 turbo
Z32afm
Apexi Power fc w/hand controller
Tomei turbo outlet pipe
Flexi 3.5 inch pipe de-cat pipe
Fujitsubo twin pipe cat back
(Second twin canon straight pipe cat back)
Sertrab oil cooler & relocation kit
Koyo radiator
Custom oil catch can (motor suffers no blow by)
Full spread of greddy warning gauges
Apexi avc-r
Apexi evc not currently fitted
Tuned for maximum reliability by Racepace in Melbourne- 235rwkw @1.1bar
S14 5spd box
Nismo super copper mix clutch/flywheel kit
ATS mech 2 way LSD
Tomei tri point strut brace
NAGASA front qtr panel braces
JDM tein super street coilovers
Whiteline adj front sway bar
GTR rear sway bar
Cusco - castor rods
- rear traction arms
- rear camber arms
- rear lower control arms
Rear cradle bushes replaced by Pedders south melb, and at the time new rear pickup points were boxed and designed to improve rear geometry, improving grip.
R32 GTR 5 stud conversion incl brakes.
Volk te37 17x9 & 17x9.5 wheels- fitted with near new Yokohama A048
Re-sprayed by Vu @ DT panels in 2008- in championship white, this was a glass out inside and out paint job.
Brick headlights
Aero front bar
Plastic option side skirts
Plastic option rear pods
Vented hood fitted with aerocatch
Car comes with standard hood, also with aerocatch
There are also two boot lids, one has an alloy wing fitted, one is blank.
Custom built CAMS approved half cage with side intrusion bars, designed and fabricated by Derek at Motorsport engineering in Moorabbin at great cost.
Two bride buckets,
nardi wheel
M"s short shift kit
Nismo gear knob.
I should make mention the car is a 1989 model and therefore eligible for Club Registration & odometer has stopped working.
The car has quite a collection of high end Japanese aftermarket components, that were ALL purchased by me along the ownership journey,
I have no doubt missed some information,
I will only consider a trade with an R32 GTR- otherwise it's a cash only sale.
$17000
Contact-
Greg
0401 873 739
post-9640-14103120622155_thumb.jpgpost-9640-14103120895235_thumb.jpgpost-9640-14103121830642_thumb.jpg
https://www.sau.com.au/forums/topic/448481-nissan-s13-silvia-vic/
Thanks ^^
Car is also fitted with an ARC front mount intercoooler kit, nismo thermostat & rb25 engine fan.
The car has rolled and flared original metal guards front and rear also- this was done prior to paint work.
I'm sure there is more, but I think I've got the general information about the car down here.
NO!
This car is about perfect in my eyes!!!! It is just about everything I have tried to do with my club street car only neater and tidier! LOL the only thing it msised was 8 pot Indycar brakes :)
Shame to see it go, hopefully finds a good home!
  • 2 months later...
  • 4 weeks later...
  • 3 weeks later...
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
