Wheel Alignment Question, Car Feeling More Skittish
Welcome. There are many similarities and some key differences between the 2. Plenty of information on both in this forum. I hope you find the information you seek.
hello everyone, an RB26, or RB25 project in the medium long term. I don't know much about this engine or turbo engines in general, I'm here to understand and gain knowledge. I have specific objectives for a project
Much less twat-tastic. CF wheels are too garish for civilised use.
From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
